How hard is it to tune these trucks??
Old Sep 4, 2003 | 02:07 PM
Default How hard is it to tune these trucks??
How hard is it to tune these trucks. Im thinking about getting LS1 edit and just tuning my truck myself when the blower and injectors get here. What do you guys think?? Is it that hard to do?? I understand how everthing works so its not like i dont know anything at all about it. thanks
Old Sep 5, 2003 | 02:58 AM
Default Re: How hard is it to tune these trucks??
i guess its harder to get a reply than it is to tune the trucks???
Old Sep 5, 2003 | 03:05 AM
Yelo's Avatar
it doesn't seem that hard to do.....as long as you are knowledgeable as to how the changes to the tune will translate into real world performance you should be fine
Tokez420's Avatar
its easy :p
Old Sep 5, 2003 | 07:54 AM
BigTex's Avatar
I think you can handle it, especially if you buy a wideband.
I tested out the "beta" 1.3 of Edit last week. Its supposed to let us tune in the truck on the 03s. Well, didn't work. Had to get the PCM reflashed.
Old Sep 5, 2003 | 04:01 PM
MNC5's Avatar
Old Sep 5, 2003 | 10:10 PM
BigTex's Avatar
Don't fret it Dennis. Its all good now.
I've got a little story for you too. Got a call today from a local speed shop needing to borrow my harness because they did the same thing. Guy at the dealership told him I had the harness and gave him my info. That truck just got heads cam and a direct port system. Best part is - they had it strapped to the dyno with the front drive shaft off!
Old Sep 6, 2003 | 12:51 PM
the wideband is just a more accurate tool to measure the A/F ratios right?
I would also need autotap to see all the other numbers as well right?
The main thing that im worried about it reprogramming for the bigger injectors, but i dont know if that will be difficult or not.
Also since i am doing this i dont need to run the boost referencing FMU that comes with the blower right?
ARC
57
Feb 21, 2022 10:54 AM
SLOPONY
20
Oct 18, 2016 06:05 AM
wrb002
Aug 31, 2015 12:00 PM
Ketis
Jul 23, 2015 12:37 PM
black6spdz
Jul 16, 2015 01:32 AM
