returnless to return system hot to request
Old Jan 17, 2007 | 08:18 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
racetronix can hook you up with whatever you need fuel system wise, thats the dual intank setup I am fixing to install in my truck once it gets warmer outside so I dont light myself on fire with the heaters
Old Jan 17, 2007 | 09:53 PM
thunder550's Avatar
High on diesel fumes
What kind of power levels are the stock lines good to on a return system?
Old Jan 17, 2007 | 10:34 PM
1slow01Z71's Avatar
I dont think Parish upgraded his feed line till he went to vic jr. Either way Ill let you know shortly
Old Jan 17, 2007 | 10:39 PM
thunder550's Avatar
Good. I don't want to change mine.
Old Jan 17, 2007 | 11:28 PM
Revolutionary's Avatar
If I were you with your future plans I would just do my own fuel system get yourself the fittings and eliminate the pickups and turn your fuel inlet to a fuel level sender and return only.. mod your fuel tank and run an Aeromotive A1000 pump with -10 line up to the firewall split off feed both rails and run a single reg with the return back to the tank. I think with enough ingenuity you could turn your exsisting supply into a return line and you would have yourself something that is capable of single digit fueling.
Just a brainstorm
Ken in AZ
Mar 26, 2016 12:05 PM
Sevex
Aug 22, 2015 12:12 AM
05GMC4.8
Aug 7, 2015 09:55 PM
MS3Z
Jul 30, 2015 06:17 PM
Mzay
Jul 6, 2015 11:03 PM
