LS1 e-fans = Silverado e-fans
Old Aug 20, 2006 | 05:43 PM
Beastofa327's Avatar
Default LS1 e-fans = Silverado e-fans
Are the LS1 e-fans the ones everybodys putting in thier trucks? Also Is it the ones on ebay, and what else am I gonna need?
Old Aug 20, 2006 | 05:49 PM
Tan327's Avatar
A lot of people are running LS1 fans, check on LS1Tech and you can find them pretty easy.
Old Aug 20, 2006 | 09:43 PM
you can use any years LS1 fans and you can use LT1 fans too. yes they are all over ebay. i wouldnt pay more than 100 for them because if they get too expensive wait a few days and more will come up
Old Aug 23, 2006 | 01:18 AM
stone150's Avatar
got mine for $40 from ls1tech
Old Aug 23, 2006 | 11:30 AM
Registered User
check out nelson performance for the wiring harness, all plug n play and it saves soooo much time and work!
Old Aug 23, 2006 | 11:59 AM
Wilde Racing's Avatar
How do I change this text
ld try and find 05 fans, I had overheating problems with the lt1's....
Old Aug 23, 2006 | 11:31 PM
negativeswitches's Avatar
i have a/c cooling problems with the ls1's, i just need to make condensor to rad gap gaurds to suck more air through the fins
Old Aug 23, 2006 | 11:43 PM
budhayes3's Avatar
PT's Slowest Truck
I'm more than happy with my 05 efan set-up....granted it's more expensive than some of the other options (since it requires the 34" rad), but the fitment is a direct bolt in and the fan operation has been flawless so far
Old Aug 24, 2006 | 12:19 AM
99LoweredSierra's Avatar
where does most get the 05 e fans and radiator? So yall suggest that over the ls1 fans?
Old Aug 24, 2006 | 01:28 AM
if you can afford it yea go for it and im pretty sure you can get it gm parts direct
