recommended exhaust size for mostly stock 5.3?
Old Aug 9, 2005 | 04:23 PM
getchusum99's Avatar
Default recommended exhaust size for mostly stock 5.3?
which do u guys think is the best setup for my truck , i have no cats and i want duals, either one mufffler with dual outlets or two mufflers with single outlets. im thinking of the hooker aerochambers, 3in/3out ,is that too much flow for sufficient back pressure? or should i go with 2 1/2? i want a deep aggressive sound and good torque. thanks
Old Aug 9, 2005 | 04:35 PM
three83's Avatar
If you run true duals, I go with an x-pipe setup, with 2.5 inch pipe.
Old Aug 9, 2005 | 05:20 PM
2000SilveradoLS15.3's Avatar
I have had true duals on mine since I bought it in August of 99.....2.5" all the way back with 40 series Flows.
Old Aug 9, 2005 | 06:09 PM
bluecajun5.3's Avatar
11 Second Truck Club
this should be a good starting point for you. i plan on doing this upgrade in the future except with 2 3/4 or 3 in.
Old Aug 9, 2005 | 07:41 PM
ReedyCreekRacin's Avatar
2.5" true duals w/ no cats on mine. ive got 40 series flowmasters. i dont think 3" is necessary. definitely use 2 mufflers, single in/out. CHIP
Old Aug 9, 2005 | 08:37 PM
do i have to use an x-pipe? also could i use the magnaflow dual in/out ive heard so much about on here? or what do yall reccommend ?
Old Aug 9, 2005 | 08:55 PM
white1's Avatar
If you dont do the "X" pipe, deffinaltly use the dual in/out magnaflow. And go with 2.5" pipe.
Old Aug 9, 2005 | 11:15 PM
zippy's Avatar
2 1/2 for sure. unless you're running alot of boost or a big cam you aren't going to gain from 3" duals on a 5.3L.
Old Aug 10, 2005 | 08:34 AM
so what do u guys think 2 1/2 bullets or aerchambers? with turndowns probobly.
Old Aug 10, 2005 | 10:38 AM
12sec.5.3's Avatar
I have a custom 3" true dual with H-pipe setup on my 5.3 and performs great with awesome sound. It just gets annoying rattling everything in the cab.
