recommended exhaust size for mostly stock 5.3?
which do u guys think is the best setup for my truck , i have no cats and i want duals, either one mufffler with dual outlets or two mufflers with single outlets. im thinking of the hooker aerochambers, 3in/3out ,is that too much flow for sufficient back pressure? or should i go with 2 1/2? i want a deep aggressive sound and good torque. thanks
Originally Posted by three83
If you run true duals, I go with an x-pipe setup, with 2.5 inch pipe.
this should be a good starting point for you. i plan on doing this upgrade in the future except with 2 3/4 or 3 in.
