Recipe for 13's in a 5.3
OK so what cam can i use to hit a 13 in a 2000 RCSB with a 5.3? N/A
I will be using the I6 Trailblazer converter, and a Nelson tune, 3.73's on a 16in rim
Or what will help me hit that number. Thanks
High 13's will be easy to hit with a cam, LT headers, stall and custom tune especially since you have a RCSB and 5.3L. What is your elevation btw and where are you located as higher elevation does have an impact on your times.
I wouldn't go too big on the cam especially with the TB converter. Most guys pick a 212/218, 214,220, 220/220 or close to it with 5.3's. If you got a 3000-3200 converter you could go mid 220's if you wanted.
13s isnt going to be hard.. their is members doing 13.8 on a 3k stall lt headers 212/218 and a tune.. u could probably get away with a a cam in the high 21* duration.. max 220.. u should be able to hit it np..
Regardless he will have no trouble at all getting in the 13's or something is wrong.
