Recipe for 13's in a 5.3
Old May 15, 2011 | 05:15 PM
kr1s's Avatar
Talking Recipe for 13's in a 5.3
OK so what cam can i use to hit a 13 in a 2000 RCSB with a 5.3? N/A
I will be using the I6 Trailblazer converter, and a Nelson tune, 3.73's on a 16in rim
Or what will help me hit that number. Thanks
Old May 15, 2011 | 05:31 PM
jrmchevyman's Avatar
High 13's will be easy to hit with a cam, LT headers, stall and custom tune especially since you have a RCSB and 5.3L. What is your elevation btw and where are you located as higher elevation does have an impact on your times.
I wouldn't go too big on the cam especially with the TB converter. Most guys pick a 212/218, 214,220, 220/220 or close to it with 5.3's. If you got a 3000-3200 converter you could go mid 220's if you wanted.
Old May 15, 2011 | 05:40 PM
05gmcsierra's Avatar
13s isnt going to be hard.. their is members doing 13.8 on a 3k stall lt headers 212/218 and a tune.. u could probably get away with a a cam in the high 21* duration.. max 220.. u should be able to hit it np..
Old May 15, 2011 | 06:01 PM
grey matter 04's Avatar
13 Second Truck Club
212/218 cam with 3000 yank and headers put my xcab 13.80s on stock gears
Old May 15, 2011 | 09:01 PM
Beatdown Z's Avatar
Laid Back
Get a real converter and you shouldn't need an aftermarket cam to hit 13's...
Or just go with a mild cam, like those above me said.
Old May 15, 2011 | 09:29 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Magnacharger and skip the 13's, just go to the 12's. 13's get boring quick!
Old May 15, 2011 | 09:33 PM
00ChevyScott's Avatar
Wearin' da big hat
x2 on that
Old May 15, 2011 | 09:46 PM
Lol very TRUE
Old May 15, 2011 | 10:07 PM
6789olds's Avatar
i bet with a tune ,posi, LT headers , and a 3600 stall in a rcsb would get you high 13s
Old May 15, 2011 | 11:08 PM
I've seen this done on a 2007+ GMT900 RCSB 5.3L and got high 13's without cam. The GMT900's have the higher engine power increase and have better factory heads than the older trucks.
Regardless he will have no trouble at all getting in the 13's or something is wrong.
