Recipe for 13's in a 5.3
Old May 17, 2011 | 08:40 AM
  #21
chevrolet all the way's Avatar
i put a 5.3 in my truck with stock heads, cam, and intake mani. i went 13.6 all day long with that. had cold air, udp, long tubes, 3200 stall, 4.10s, e fans, and whatever other small stuff.
Old May 19, 2011 | 12:42 PM
  #22
kr1s's Avatar
If i get a 2600 stall can i see 12-13's?
I need to keep this city friendly, its my DD and avg speed limit is like 40-50
Old May 19, 2011 | 01:46 PM
  #23
Lil brother PI's Avatar
i would at least go with a 3200-3000 PI tends to be a little tighter than most
Old May 19, 2011 | 02:02 PM
  #24
dmelvin's Avatar
A lot of guys say that the 3000-3200 278mm Circle-D converter drives like stock under DD conditions.
Old May 19, 2011 | 02:03 PM
  #25
iamkeniff's Avatar
i have to disagree...
Yank is known for having a tighter converter, and Circle D is kind of in the middle, and PI is known for being a looser converter. anyone can make you a converter for your needs though. if you want a DD friendly id say go with Circle D's 278mm 3000-3200 converter its about 400.00 vs the price of the others. i ran the 278mm 3200 from Circle D in my CC on 3:42s and 4:10s i loved it on both gears. also that converter put my CC at 13.0 every pass, and towed just fine.
RCSB is easy, id do what grey matter 04 said:
212/218 low lift cam
Circle D 3200
3:73s
Tru-Trac
3.5" CAI
tune
Pacesetter LTs
you could see a very strong combo with that an the MPH be close to 100 every pass.
Old May 19, 2011 | 02:08 PM
  #26
never tried them....not very popular down here most people is PI but i have been in a truck that has cd and u are right they are nice and tight i had forgoten about that truck yes u are right yank have never heard or driven one
Old May 19, 2011 | 02:14 PM
  #27
kr1s's Avatar
Hmm ill see how a 3000Circle D looks on youtube.
Lol i know i'm gonna sound stupid but how do you lock the converter? You can have a tune lock it at different speeds right?
When i'm cruising do i want to have a converter locked?
Old May 19, 2011 | 02:42 PM
  #28
jrmchevyman's Avatar
12's are not gonna happen with a 2600 stall NA.
You can get into the 12's NA in a RCSB its not uncommon with like a 220 cam but, you need to have all the supporting mods and a good COMBO is the key along with a big converter, Gears do wonders too. A 2600 stall just won't get you there.
A 2600 stall is pretty small for a NA setup, it would be fine for a boosted setup though on your RCSB.
Just look at bluecajun's truck on here with a smallish TR220 cam in his 5.3L and doing 12.4 NA but he has boltons, CircleD 3C (3800) converter, 4.10's and eaton lsd with Hoosier tires.
Old May 19, 2011 | 02:43 PM
  #29
iamkeniff's Avatar
your stock converter locks at xxmph and xxmph unlocks at xx % of throttle and relocks at xx % of throttle.
you can set it up any mph/throttle position you want for your driving styles. a lot of people just leave them alone.
Old May 19, 2011 | 07:12 PM
  #30
StrokerAce03's Avatar
Bolt-on's and a good converter with traction will get you 13's easily, I'd be willing to bet you could do it without a converter really. I ran 13's with a 4.8 that had bolt-ons and a converter so I know a 5.3 would do it with even less.
