RADIX trouble ... pulling timing, can't find where
OK ... I posted this before but under burst knock. I've rulled it out. I need some help with this. Here is a snippet of a log file where it's doing it.
When I'm accelerating at part throttle, it feels like it's trying to gettie up and go, but somethings holding it back. It almost feels like it's choking out, but this log says it's timing getting pulled. I can't for the life of me fine where it's getting pulled from.
If you want some different pids listed inthis same snippet .. let me know, I probably have them logged too.
Code:
TP % RPM lb/min MAF Hz ADV KR IAT °C ECT °C CYLAIR g/cyl 47.8 2950 20.55 8512 17 0 34 81 0.79 47.8 2945 20.55 8502 17 0 34 81 0.79 47.8 2962 21.03 8543 17 0 34 81 0.81 51.4 2953 23.73 8807 13 0 35 81 0.91 57.6 2782 23.08 8841 2 0 35 81 0.94 57.3 2893 23.36 8892 6.5 1.3 35 81 0.92 57.3 2966 24.43 8979 7 1.2 35 81 0.93 57.3 2923 23.57 8974 5.5 1.1 35 81 0.91 57.3 2918 23.78 8911 6 1.1 35 81 0.92 57.3 2952 24.43 8958 8 1.1 35 81 0.94
This is the kit off of my old 2002 truck actually. I copied lots of tables over from the SuperChips program into my 2003 file. I mnually copied them since I couldn't get both files open at the same time in EDIT.
So ... to answer your question, I have the SuperChips tune as a base tune and have modified it a little to try and get drivability and idle quality back from the cam.
I think I am going to try the original file I started with and see how it does, if it has the same problem as this file does.
Good idea. I was going to advise you to go back to the beginning and start over.
What is the engine temp when it does this? Cold start up?? Does it do it all of the time???
Most of the time, it's more prevelant when it's warm. It runs at 175-180*F or 78-81*C.
BenKey .. will you send me the file to nmcdaniel@bettie.homeip.net
Thanks
Thanks
Of course there isn't much data to go from, but compare the differences between the 17* lines and the next few. What are the differences? TPS goes over 50%, cyl air goes over .90, IAT goes to 35, ... Look for similar instances on other logs and see if you can narrow down a trigger for your low timing.
Code:
I am taking the truck to a friend saturday afternoon to try and figure out the problem as I do not speak computer.
It sucks your having problems, but i'm happy i'm not the only one!
Kurt
Thanks
Thanks
