Radix pulley ?
Old Jul 2, 2005 | 07:51 AM
wkdivr's Avatar
Default Radix pulley ?
What is limit you could go down to on a 5.3, and still be daily driver friendly? The Magnuson supplied one is 3.4. Could you go as low` as 2.9, 3.0?
Old Jul 2, 2005 | 08:25 AM
I ran a 3.25" pulley with my 5.3 on the street with good results,I also ran a 3.0",but saw very little increase in power with the 5.3 so i switched back to the 3.25".With my 403 I'm running a 2.75"pulley,but would'nt recommend it with a 5.3.
Old Jul 2, 2005 | 08:29 AM
wkdivr's Avatar
Did you retune foe the 3.0?
Old Jul 2, 2005 | 08:34 AM
No,I didn't tune for the 3.0" and was afraid I wasn't getting enough fuel,so I switched back to the 3.25"with was giving 9 1/2lbs of boost.
Old Jul 2, 2005 | 08:37 AM
wkdivr's Avatar
Wow!! 91/2 pounds! Yikes!! Looks like I'll probably retune for the 3.2, too! So...you thought you might be running out of fuel? Pump, or injector, or both?
Old Jul 2, 2005 | 08:48 AM
At the time I was suspisous that the fuel pump was a problem.I was running the original MSD boost-a-pump setup with the stock fuel pump and had just replaced my second fuel pump.Now I'm running a big Edelbrock inline fuel pump along with the stock pump and 57lb injectors,but I'm running 403 cid.
Old Jul 2, 2005 | 08:51 AM
wkdivr's Avatar
I have an 04, with the Wallbro in-tank pump that Magnuson supplies. Think that would be enough? I'm looking at approx. 59-60 idle, and 56-58 at wot. That's fuel pressure, obviously.
Old Jul 2, 2005 | 09:01 AM
You should be fine with that setup and your 42lb injectors should be big enough run either a 3.0" or a 3.25" pulley,I'd go with the 3.25"my truck made 417rwhp with the the 3.25"pulley and about the same hp with the 3.0"with only a slight gain in torque.The 3.25" pulley is close to optimum with the 5.3,you start getting deminishing return after that.
Old Jul 2, 2005 | 09:22 AM
wkdivr's Avatar
Alrighty, then. Thanks for the info. 'Preciate it!
Old Jul 2, 2005 | 09:47 AM
03sierraslt's Avatar
Get Er Done Bill
Vortec350ss
Jan 12, 2016 10:36 PM
Lthompson
Oct 2, 2015 12:45 AM
old motorhead
Sep 29, 2015 08:22 PM
murderedSS
Sep 27, 2015 10:16 PM
bagged7104SS
Sep 24, 2015 08:42 PM
