Radix, poor results so far...
Old Apr 13, 2004 | 12:16 PM
  #21
F8L Z71's Avatar
Your AF looks pretty rich also but not enough to cause the problems you are seeing.
Old Apr 13, 2004 | 12:40 PM
  #22
retsell's Avatar
I like it rich, that way it won't blow up as easily.
Old Apr 13, 2004 | 12:43 PM
  #23
retsell's Avatar
I meant for the other guy having prblems with his emblem blocking the intercooler. Yours seems to have a bigger problem. Could it be that in is building up heat due to excess friction inside the blower housing and transfering that heat to your discharge air? Liek the tolerances inside the blower are too tight and parts are rubbing and causing the grinding noise you hear?
I don't see anyone else with a blocked intercooler. Just me. He said he used to, but moved it.
Old Apr 13, 2004 | 05:24 PM
  #24
Flem's Avatar
the tuning w/ my radix was way rich well over the 11.7 A/F for s/c applications it was like 10.5 :1 leaning it out was worth 22hp
Old Apr 13, 2004 | 05:31 PM
  #25
StupidFast's Avatar
I always wondered what is the average gain when installing a Radix on a bone stock 5.3?
Old Apr 13, 2004 | 05:53 PM
  #26
vortec327's Avatar
Upgrade to the heat exchanger i have. click in my sig for pics. Contact Blownchevy for purchase price.
Old Apr 14, 2004 | 12:36 AM
  #27
BigTex's Avatar
I didn't see anyone else ask this, but is the coolant pump working? One other guy had his Radix installed, and was getting "whipple-like" performance out of it. Turned out that Magna didn't have a fuse in the pumps harness, so even theough it was all hooked up, it wasn't getting intercooled boost, just hot air.
Old Apr 14, 2004 | 06:37 AM
  #28
parish8's Avatar
single digit dreamer
like tex said, is the pump working, and not just wineing. i was messing with mine the other day and if you wire it backward it will wine but only pump a little, wired properly it pumps alot of fluid.
Old Apr 14, 2004 | 09:00 AM
  #29
retsell's Avatar
It is wired properly. It pumps quite a bit of fluid, from top to bottom in the resevoir.
Old Apr 14, 2004 | 09:01 AM
  #30
retsell's Avatar
We are now looking into the blower as having a problem, too close of tolerance will cause too much heat. The blower makes kind of a coffee grinding noise while in boost, which they say it shouldn't. The sales manager ask that I put another 300 miles on the blower, and if it is still making that noise he will send me a new one and RA my old.
