Radix and longtubes?
#41
I don't think you should be as upset with Magnasun. I think you're problems lie more with your tune, so maybe you should take it up with whoever's doing the tuning. Magna does the blowers, that's thier department, and they do it very well.
If you have intermittant misfires (what the p0300 code really means), then you should start with some basic tune up items, like plugs and wires. This could have been something the installer messed up on even, maybe you should take it up with them as well. Bottom line, I think you should figure out what the problem is before you start pointing fingers.
#42
#44
Whoever told you shorties are what you need for a blower was dead wrong. Anything will benefit from a better header. The gains I noticed were all over, down low, mid range, and up high. It knocked off a consistant .3 from stepping up to the better headers. I also ditched the hollow cat shells at the same time too.
Did you notice or dyno any sort of gain from the TOG's? The TOG's are not shorties. They are equal length mid headers.
#45
Originally Posted by GREGGO
The cats do not move with AS&M longtubes.
It looks like I am going with the TOG's. I just do not want to deal with carb. Hopefully they will show some gains and hopefully I feel it.
#46
I went from TOG"s to PaceSetters. I said, whoever said that a RADIX wouldn't benefit from long tubes as well as it would from shorties were dead wrong. ANYTHIGN will benefit from a better header.
dhpro, you must understand, Magna has a company policy to follow. While they can recommend other modifications, they can't support it because that makes them liable for any other damages incured and also makes them liable for any other aftermarket modification. Once you start deviating from their stock tune for the stock truck, you must look elsewhere for tuning.
Just a general rule of thumb, misfires are not usually at fault of a tuner. Knock or detonation is, however, p0300 is not a code for knocking or pinging.
#47
In my case the install of Dynatech LT's resulted in SOTP increases everywhere and reduced my 1/4 mile ET's by a consistant .5 second as measured by a G-Timer. Don't know if shorties or mid lengths would have netted better results. I doubt it.
#48
#49
Again, you need to install the supplied tune and trouble shoot from there. Returning here daily and beating the dead horse will get you nowhere fast.
Please let me know if you intend on taking the advice I have given you, if you do not we will proceed with the buy back of your supercharger system.
#50
