Radix Installed
Old Aug 8, 2005 | 10:15 PM
  #31
BigBlackAv's Avatar
might be another silly question....but what elevation are you at?
Old Aug 8, 2005 | 10:16 PM
  #32
BlownChevy's Avatar
blownerator
25 Year Member
Originally Posted by DrX
Just took it for a hard drive. Outside temp was 70 degrees. BTW my outside temp sensor is now reading the temp of the air that has passed through the intercooler heat exchanger because it sits right behind it. Will have to relocate it if possible.
Definitely running better but still seems that the PCM permanently cuts me back a little more after every WOT launch. Started out with about 5 ft of tire squeal(don't know what this thing should be doing). By the end of testing I was down to a chirp(first run after install last week did about 20 ft on the exact same spot-with some pinging). Can't say for sure that I noticed any ping. Could just be paranoid.
Don't think I can blame anything on the gas now. It would be impossible to tune one of these to run at higher boost levels if 94 octane is not good enough for the stock Radix setup. Could be that the 94 is just masking something else.
It's not bad so I'll drive it for a while until the rest of my gauges come in. Will talk to the guys at the shop that's getting them about putting the AV on their dyno.
Have installed and reinstalled the Radix tune. Factory tune is probably only good for idling now.
have you verified that your I/C pump is working?
  #33
BigBlackAv's Avatar
with respect to sea level...btw .... ups says my radix will be here tomorrow....sweet!
Old Aug 8, 2005 | 10:40 PM
  #34
DrX's Avatar
DrX
Roughly 750 ft.
Old Aug 8, 2005 | 10:43 PM
  #35
DrX's Avatar
DrX
Yes and I was impressed at how cool both hoses felt after my run.
Old Aug 8, 2005 | 11:24 PM
  #36
BlownChevy's Avatar
blownerator
25 Year Member
please look and verify the pulley size on the blower.
Old Aug 8, 2005 | 11:50 PM
  #37
DrX's Avatar
DrX
The pulley is a 3.4
Old Aug 9, 2005 | 06:11 AM
  #38
BigBlackAv's Avatar
damn...that is not very high...I'm all out of ideas...this weekend I will be putting mine on and maybe I'll come up w/ something them.
Good luck and keep at it.
Damon
Old Aug 9, 2005 | 09:15 AM
  #39
DrX's Avatar
DrX
[QUOTE=krambo]Peak MAF readings seem a little low to me at WOT,...anyone else? Did you monitor KR.
Scanner doesn't monitor KR or KCs in OBD2 mode. Timing was 16 at WOT.
Old Aug 13, 2005 | 12:53 AM
  #40
DrX's Avatar
DrX
Just RnR'd the Radix-broken intake bolt-oops. Always fun climbing into the engine bay to set that thing into place. Seemed to run a little stronger now.
Also installed the Dynojet Wideband Commander.
A/F:
Idle-15 average
Cruising-14.7/14.8
WOT-11.8 (I think it was around 12.5 before the RnR??)
Will get it on a dyno ASAP to see what it is doing now.
Also noticed that where the intake casting bolts to the rear of the blower there are 3 upper bolts and only 2 lower bolts and an empty bolt hole on the right side. Is this the way they are all assembled?
LCHEE
Oct 24, 2020 04:10 PM
zblee
Aug 3, 2015 03:45 AM
therock
Jul 25, 2015 09:23 AM
FlowmasterMufflers
Jul 17, 2015 03:26 PM
sTNT971
Jul 16, 2015 12:39 PM
