Radix Installed
Dude...that sucks...have you made any other mods to the truck?...is there anyone around you that coan look at your tune?...wait...just noticed your sig...the 3.73 dont help any but i would think it should feel stronger than "stock" (and should be able to shred some rubber).
Good luck,
Damon
Good luck,
Damon
Good luck,
Damon
Good luck,
Damon
If you have traction control turn it off or it won't run good and make sure that the intercooler tank is full and that the water is flowing good. If you have a scanner check the timing should be around 15-17 at WOT and the stock o2s should be in the 890-920mv range at WOT
BTW. Thanks for your input guys.
hey what kind of scanner do you have?
You should be able to boil them with what you have. I know I could when i just had the Radix, and I have the tires to prove it.
my truck has 3.73 also so that isnt going to be the problem.
timing 16
both O2s 905
IAT: 68 at startup, on the road it went from 100 to 118 during boost
MAF: at idle 0.75lb/M(5.6 g/s), WOT- maxed at 38lb/M(285g/s)
MAP: idle 10"HG(34 kPa), WOT- maxed at 30.4"HG(103 kPa)
*edited to add units of measure
