Radix GT2-3, LS2 90MM TB Results 94 RWHP
Old May 5, 2006 | 02:23 PM
BlownChevy's Avatar
blownerator
25 Year Member
Default Radix GT2-3, LS2 90MM TB Results 94 RWHP
Here is the mix:
2001 GMC Yukon
5.3L
Radix 3.2 pulley
GT2-3 Cam
LS2 TB Conversion w/ West Coast Cyl Head flange
21* of timing
11.99-12.0 AFR W/ Wideband
**NOTE THE LAST PULL WAS WITH THE CUT OUT OPEN
I have come to the conclusion that this is the BEST street set up you can get! The LPE GT2-3 Cam and Radix/90mm TB set up complement each other well!
here is a copy of the dyno chart so you can see how well the parts work together.
Old May 5, 2006 | 02:31 PM
leftcoast32's Avatar
FormerVendor
Very nice work!!
Old May 5, 2006 | 02:33 PM
ColtSteele's Avatar
Great job and great combination.
Old May 5, 2006 | 02:44 PM
ZR1 DREAMING's Avatar
Good info Brian!
Old May 5, 2006 | 03:05 PM
Richard@WCCH's Avatar
FormerVendor
Wow Brian!! What a fantastic package.
It looks like proper tuning will be required to see maximum potential from the 90mm upgrade.
Nice work Brian. Thanks for posting this info.
Richard
Old May 5, 2006 | 03:07 PM
thunder550's Avatar
High on diesel fumes
What are the specs on that cam?
Old May 5, 2006 | 03:11 PM
moregrip's Avatar
what a rush!
+90rwhp +30rwtq, that'll do just nicely. Also there looks to be no loss in TQ at the lower rpms and increased TQ being realized @ approx 2700rpms. I bet that heavy suburban likes some of that action
Old May 5, 2006 | 03:18 PM
kbracing96's Avatar
I belive these are the specs
207/220 .571/.578 118.5 LSA
BlownChevy's Avatar
blownerator
25 Year Member
sounds about right
Old May 5, 2006 | 03:25 PM
kbracing96's Avatar
Not too far off from my cam, just a little bigger
02+ LS6 cam 204/218 .551/.547 117.5
