Radix Cam Experts...Need Recommendations/Advice. Tax Time is just around the corner!
Old Dec 29, 2004 | 10:19 PM
  #41
Mr. Sandog's Avatar
Originally Posted by moregrip
Here's an SLP Cam that might be good:
Looking for a major performance improvement from your LS1-powered car or truck? This cam was designed with performance and driveability in mind. SLP engineered this cam to deliver the best throttle response, torque and horsepower available and has optimized a specific profile for both automatic or manual equipped cars. In the case of the F-car, you can expect an improvement of up to 25 hp over the stock camshaft. Quarter mile times can be reduced by as much as 3-4 tenths.
Camshaft Specs: Valve Lift Duration Duration@.050
in: .559" 267º 214º
ex: .566" 275º 222º
Centerline - 111º
Lobe Separation - 115º
thoughts?
Well, that looks hauntingly like Comp's LS1 3710R/3714R 115+4.
Maybe because it is?
This SLP cam (Comp Cam actually) and Cam Motion's are nearly identical in specs. The only difference would be how exactly the different company's lobes control the valve events. But I would bet they would be very similar in behavior.
Old Dec 29, 2004 | 10:22 PM
  #42
moregrip's Avatar
what a rush!
Originally Posted by Flyer
Do you have headers on your truck? True duals? Give some detals on the exhaust and/or any future plans on it.
I will be putting some Mid Lengths on. Other than that the exhaust is pretty robust. Daul 3" into a Mangnaflow 22" case muffler (Internal Y) into a single 4" Outlet.
  #43
moregrip's Avatar
what a rush!
Good info, thanks
Old Dec 29, 2004 | 10:43 PM
  #44
Flyer's Avatar
I wouldn't go with that large of a split then. I would stick with 4-6* split, 6 being the absolute most.
Old Dec 29, 2004 | 10:46 PM
  #45
moregrip's Avatar
what a rush!
what are you saying?
Old Dec 29, 2004 | 10:49 PM
  #46
Flyer's Avatar
212/218 ... that's 6* split ..
216/220 ... 4* split.
If you had the stockish exhaust, I'd say go more, like 6-8, maybe even as much as 9 or 10 if you wanted to go all out.
Old Dec 29, 2004 | 10:50 PM
  #47
moregrip's Avatar
what a rush!
ahhh, got it, I was trying to figure out what you thought of my exhaust flow
Old Dec 29, 2004 | 10:54 PM
  #48
Flyer's Avatar
Once you get the hedaers .. it will prolly be better than average.
Personally .. I'd rather have a dual in dual out muffler though.
Old Dec 30, 2004 | 05:14 AM
  #49
sfj
is it just me or do a lot of people prefer a reverse split cam when using nitrous and blowers etc... i after reading this post do not see a single mention of a reverse split cam so i am just wondering ... any body have any input on this
Old Dec 30, 2004 | 08:39 AM
  #50
Sport Side's Avatar
Reverse-split camshafts are more commonly used in setups that have a free-flowing exhaust, and a restricted intake flow. When the intake charge is assisted (nitrous, blower), you may fatten up the exhaust lobe to help release the gases.
Example.
346ci LS1
stock manifold
off-road exhaust
long tube headers
stock heads
-Might require a fatter intake lobe.
Example.
325ci LM7
200 wet shot
FAST manifold
Stock exhaust
-Might require more exhaust lobe, to help expel gases.
Make sense?
