Radix Cam Experts...Need Recommendations/Advice. Tax Time is just around the corner!
#51
yeah it makes sense that since your using a 200 wetshot or similar to FI the motor you will want a bigger exhaust lobe to help pull the exhaust out but isnt the nitrous going to have a similar effect of his blower and would you still not want the bigger exhaust lobe sorry for the questions i just want to understand what would be the difference in the nitrous reverse lobe since you are essentially forcing nitrous in there and the blower forcing air in there???
#54
Yeah, it's a similar effect. Air that is assisted entering, can use a smaller intake lobe. But a larger exhaust lobe may be used to feed the extra air (from the power adder) out of the motor.
#56
I'd think you might try adding some more lobe.
@ .05 with that 205/210 114 you'll have -20.5 degrees of valve overlap. Not to mention you have more cubes w/ the LQ4.
You have plenty of room to pass emissions.
#57
Originally Posted by moregrip
Heres a new recommendation from Futral:
We can do you a 205\210 .550"\.544"-114 that will keep good low\mid TQ and still pass CA emissions.
thoughts?
thoughts?
#58
Originally Posted by Naked AV
You probably already know all of my thoughts on cams by now grip-man, but that is essentially my cam, and nearly ideal for a stock TC in a 5.3L. While you certainly won't lose anything with that cam (it will be an improvement over your stock 196/207, .467/.479, 116), you would be leaving a lot on the table.
Thing is, I really like the 214/220 214/222 cams that seem to be collectively recommended......but then I really need a daily driveable Cam as well, a no problem ordeal (once tuned of course), sounds like that wouldn't be an issue with my 364 cubes.................does everyone agree the above is a daily driver?
#59
The above would be a very well manered daily driver in a 5.3. My 216/220 has me a believer. It has very little lope and only a little cold start problems, but that's just because I've been lazy with the tune since I've had to pop the hood and get wrenches out to tune.
*waiting impatiently for HPT to be shipped*
#60
