Radix Cam Experts...Need Recommendations/Advice. Tax Time is just around the corner!
Old Dec 30, 2004 | 08:15 PM
  #61
Mr. Sandog's Avatar
I think a 212/218 in your truck would behave in a similar manner to the way the 205/212 does in mine. If you're a little nervous and want to be safe, I'd say get a 210/218 like marc_w has in his truck. With your stock converter stalling at ~2500 RPM, you should have no problems moseying around town, as well as having fun on the on-ramps. There is little to no risk with this choice, IMO.
OTOH, you could roll the dice and get a 214/222 or something similar and see what happens...now that feels a little more exciting, doesn't it?
Old Dec 30, 2004 | 08:24 PM
  #62
Sport Side's Avatar
I think Comp's 212/218 (-13* of overlap @ .05) will be similar to C-motions 214/222 (-12* of overlap @ .05). Cam-motion's will act a bit bigger with more duration @ .006 and .05 and added overlap. Compare that to Nakids w/ nearly -20* of valve overlap @ .050 .
'lil bit of editing does the trick
Old Dec 30, 2004 | 08:33 PM
  #63
Sport Side's Avatar
Coming from a guy that lives in Cali, a 346 on a regular ol Comp lobe can pass with about -3, -4* of valve overlap @ .05
Now. People are always talking about the TR224 on a 114lsa is the biggest you can go and pass smog. Lets take a look at it. It has -4* of valve overlap @ .05 . How about that!
With your larger cubes, you could easily step up a bit and pass smog.
Old Dec 30, 2004 | 10:11 PM
  #64
moregrip's Avatar
what a rush!
Originally Posted by SportSide 5.3
By the way. Don't be scared away of going a bit bigger. You're already limited to so much having to pass Cali's smog rules so you aren't going to be shooting raw Radix boost out the tail pipe.
With your larger cubes, you could easily step up a bit and pass smog, and have plenty of useable power.
SportSide, really appreciate your insight, helps to hear others concur on Cam Specs for my application. Where did you learn all your Cam knowledge?
Old Dec 30, 2004 | 10:24 PM
  #65
Sport Side's Avatar
ha, no problem. here, family, magazines and just buggin people with questions.
Old Dec 30, 2004 | 10:26 PM
  #66
2toneblown's Avatar
wouldnt use harland sharps. we have used 2 sets and both cars have had one come off due to the bolt breaking off.
Old Dec 30, 2004 | 10:27 PM
  #67
moregrip's Avatar
what a rush!
it's nice to have a good discussion on Cams like this, thanks to everyone for their contributions and advice!
Still trying to decide. That recommendation from Allan really threw me off.
Old Dec 30, 2004 | 10:28 PM
  #68
moregrip's Avatar
what a rush!
the 8mm Bolt that secures the rocker?
Old Dec 30, 2004 | 11:02 PM
  #69
2toneblown's Avatar
yea the bolt is just too weak and it puts too much pressure on it and it just breaks off in the head. We talked to them and they said we are not the first people to have this problem. sounds safe to me.......NO
there is no reason to change rocker arms. we have cars running 9.25s with stock rocker arms
Old Dec 30, 2004 | 11:07 PM
  #70
moregrip's Avatar
what a rush!
Thanks, I'll just replace the bolts with stronger bolts, or some studs. Thanks again for the info
