Radix Cam Experts...Need Recommendations/Advice. Tax Time is just around the corner!
#31
Originally Posted by moregrip
Hey Naked, when you get a chance look up the specs on a X2081-2152 and tell me what you come up with?
As far as overlap, I'm not sure, to calculate it I think you need more info than you've been provided with. Maybe call and ask Terry, and/or see what BigTex has to say, he's the man on cams.
#32
Originally Posted by Naked AV
207/214, if memory serves me correctly.
#33
Maybe....I could be referencing an old lobe sheet. According to my materials, the following are 214 lobes (with associated lifts): X-2122 (.329), 2141 (.311), 2151 (.345), and 2181 (.279). The only 222 lobe I found is X-2232 (.287).
Just guessing, maybe your grind# is X-2181/2232-15+4
Course, any of this info could be outdated or superceded.
#34
Any of this info could be outdated or superceded.
To other Cam guru's: any other things I should be considering here? Am I in the ball park?
#37
Just wondering, but why would you consider the Lingenfelter GT2-3? Two people have Radix, custom spec'd camshafts and neither come out looking like it.
You have Nakid w/ a 205/212 114ld & Grip w/ a 214/222 115ld
I understand that we're not looking at all of the specs, but seriously. A 118.5* lobe distance and a 13* exhaust bias. Watch out.
I'd go thru the trouble of filling out Cammotions cam form (btw - it took me longer to register than to fill out the form. We are talkin 2 minutes
for a custom spec'd cam to your application), before taking a wild guess with the gt2-3.
#38
Here's an SLP Cam that might be good:
Looking for a major performance improvement from your LS1-powered car or truck? This cam was designed with performance and driveability in mind. SLP engineered this cam to deliver the best throttle response, torque and horsepower available and has optimized a specific profile for both automatic or manual equipped cars. In the case of the F-car, you can expect an improvement of up to 25 hp over the stock camshaft. Quarter mile times can be reduced by as much as 3-4 tenths.
Camshaft Specs: Valve Lift Duration Duration@.050
in: .559" 267º 214º
ex: .566" 275º 222º
Centerline - 111º
Lobe Separation - 115º
thoughts?
in: .559" 267º 214º
ex: .566" 275º 222º
Centerline - 111º
thoughts?
