Radiator Options
Old Feb 29, 2020 | 09:13 PM
Vetteman61's Avatar
Default Radiator Options
Hello,
I'm looking for a radiator but I need some help. I'm using a stock 5.3 from a 2004 Avalanche in a 1978 Caprice. I want to install a stock radiator from a Chevrolet truck, but I don't know much about the differences between the years and option packages. For example, would one from a 6.0 or 2500HD be a heavier duty radiator and cool better? A diesel? Are there certain years or types that are known to be problematic and to be avoided (random example: maybe the fittings leak or crack on a certain year or type?) I'm looking for something that has factory dual electric fans that mounted to the radiator. I would prefer to use one from a 2004 model to keep everything from the same type of donor vehicle so it's easier to keep track of, but if there are reasons a different year would be better I would like to know.
Thank you,
Old Mar 1, 2020 | 07:51 AM
madmann26's Avatar
The HDs have a bigger radiator, 34” I believe.
Old Mar 1, 2020 | 08:07 AM
Merctech2's Avatar
For the trucks that came with clutch fans which if I remember 99-04, radiator was 28” then they switched to electric fans 05 was 34”.
Old Mar 1, 2020 | 08:52 AM
MikeGyver's Avatar
What is your location, and FYI look at the build link in your signature:
BlackLM7
Apr 27, 2021 04:37 PM
URLIFEWASOC
Jun 28, 2010 09:12 PM
McKlusky
Jan 30, 2006 01:34 PM
Joe Hay
Jun 17, 2005 04:24 PM
Pewter Pro-Tec
Dec 23, 2004 08:21 PM
