Racetronixs 255 and Hotwire Crap !
Old Sep 25, 2007 | 07:51 PM
Casey2323's Avatar
Default Racetronixs 255 and Hotwire Crap !
I have a 255 and Hotwire Kit installed on my truck... Before I installed this my truck made 48psi at idle... 02 Chevy 1500 with a Factory 5.3 NON Flex fuel .. I installed the pump and hotwire kit and didnt pick up much.. changed the regulator and checked the bucket 5 times .. I had a whipple with 10 wide open injectors.. so i blamed that.. called it done ..... NOW I have 60lb injectors I removed the line from the Reg and new tune.. Truck now makes 56psi at idle with little over half a tank of fuel... Top of first.. fuel pressure drops... it holds till top of 2nd then falls off HARD down to 20-25psi !! ... of course truck goes instant Lean .. WTF is the problem !!!!! I am Sick of this crap.. I checked the fuse and relay for the hotwire kit.. everything looks good... so before i refuse to take the blame for this Crap.. its NEVER done right since day one ..
Old Sep 25, 2007 | 10:54 PM
Casey2323's Avatar
truck is boosted... 10psi during my test runs today...
Old Sep 26, 2007 | 07:04 AM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
When you say you removed the line from Reg, do you mean the vacuum line on the regulator?
Old Sep 26, 2007 | 08:45 AM
Casey2323's Avatar
sorry ... Yeah no Vacume line to the Reg... I was told people Gut the factory one and install an aftermarket unit on the return side... but I really dont see hows possible....
Old Sep 26, 2007 | 08:47 AM
Casey2323's Avatar
Default fuel pressure
sorry ... Yeah no Vacume line to the Reg... I was told people Gut the factory one and install an aftermarket unit on the return side... but I really dont see hows possible....I guess tonight i can pull it out again... and check powers and grounds... My biggest concern was the camaro harness installed on a truck.... KC
Old Sep 26, 2007 | 01:06 PM
I AM A MOTHERF*CKER
If you pull off that vac line, the regulator can't adjust to idle vacuum or boost. Plug that bad boy back in and try it again.
You shouldn't be loosing pressure.
Old Sep 26, 2007 | 01:09 PM
Quik's Avatar
5 year bitches!
Originally Posted by Quik
what are you tryng to ask. i read your post twice and cant follow it..... a truck harness isnt no different then a cars harness. ive made a few standalone harness and know that either harness will operate any of the motors.
if your having fuel issues, you could have a restriction in your line, or not enough line to feed the motor
Old Sep 26, 2007 | 10:56 PM
Casey2323's Avatar
Default problem??
There is a brass nipple on top of the pump?? its leaking all over??
Old Sep 26, 2007 | 11:56 PM
Casey2323's Avatar
Reading threw... http://www.racetronix.com/RX-F99-FPKG-2.html Talks about the Venturi system .. its used to suck fuel back into the bucket... I am sure this is my problem... but how am i going to fix this??? new pump? new sending unit?...
Old Sep 27, 2007 | 08:40 AM
I AM A MOTHERF*CKER
Did you reconnect the vacuum line to the regulator before you started down this path?
