Quick Radix Pulley Install Question
Originally Posted by BLACK 5.3
cool..thanks.. im thinking Vise grip to hold pulley in place then air gun the fu%^er off ..
i have tried like 2 or 3 times to get that bolt off there is this yellow glue stuff on there will try your method thanks.....so which side to turn bolt to unbolt from charger left or right ???
Destroyer of Transmissions
Originally Posted by KySilverado
Turn left to loosen. The Nelson pulley I have, has a a nut machined in to put a wrench to. The stock radix pulley didn't. The belt wrench worked. I remember couple posts on using an impact. Do a search. Best I remember it was not advised to use one. The gears in the front snout could be damaged.
My method:
strip of old belt to go around pulley, large craftsman strap wrench over that strip of belt (so you get full contact with the pulley ribs) - 2' breaker bar on the nut, hold strap wrench (pulley) - Bam, popped loose first tug.
Use puller to get the pulley off, and I was only able to get Allen's pulley on right up flush to the threads, so I used a socket and mallet to get it further, then used the nut to push rest of the way. 45 ft.lbs, no locktite
I used this method after Brian told me NOT to use an impact. Although I have heard from more than a few people that they used an impact with no problems. My method is pretty easy and harmless though if you haven't used an impact yet.
Originally Posted by BlownChevy
DO NOT USE ANY AIR TOOLS ON THE NOSE OF THE SUPERCHARGER.......YOU MAY NEED A BELT WRENCH LIKE 03GMC IS TALKING ABOUT....
DO NOT USE ANY AIR TOOLS ON THE NOSE OF THE BLOWER
therock
Jul 25, 2015 09:23 AM
FlowmasterMufflers
Jul 17, 2015 03:26 PM
