quick question
Old Sep 25, 2006 | 06:05 PM
LesPaul's Avatar
Default quick question
hey i got the engine running good... turned out to be injectors so i put the 5.3 rail and injectors on till tomarow.... anyway so i was refilling my coolant and i looked down and the collector on the headers were glowing red.... not like cherry red but had a red tint to them.... now i havent ever really looked at them when the truck is hot but is this normal or not..... engine isnt over heating or anything just the headers are getting really hot....... now obviously i understand that the truck might be running a little lean with the 5.3 fule set up... so just give me a little input
Thanks
LES
Old Sep 25, 2006 | 06:21 PM
CHEVRACER83's Avatar
Is it hot right now or just red from getting hot before?
Old Sep 25, 2006 | 06:26 PM
BADMOFO's Avatar
Cuz I AM a BADMOFO
Hot = Lean. The 5.3 injectors and the 6.0 injectors are the same. You've got a fuel problem somewhere. The tune won't make it "that" lean. Don't stand on it too hard until you figure out your problem. I'd check the fuel pressure.
Old Sep 25, 2006 | 06:29 PM
LesPaul's Avatar
i got the 6.0 tune in it now.... just desnt make any sence.... the 5.3 didnt run lean.....they were turning red after holding it at about 2500 rpm for 30 seconds
Old Sep 25, 2006 | 08:31 PM
LesPaul's Avatar
looking at the injectors they look different in the way that thier is 4 hole spray on the 6.0 injectors and thier are only 2 on the 5.3.... but the 5.3 do look a tad bit bigger not sure if they would put out the same fuel... none the less when i release the pressure on the rails thier seems to be plenty of pressure...
Old Sep 26, 2006 | 08:51 PM
BADMOFO's Avatar
Cuz I AM a BADMOFO
Did you get this str8 yet?
Old Oct 2, 2006 | 03:40 AM
LesPaul's Avatar
yeah..... not sure what the hell it was but it seemed to fix its self... ???? im still getting a false lean code from a leaky header... BTW codes read lean 1 and 2... now im only leaking on one side.... wouldnt it just show banks 1 , 3 , 5 , or 7 lean or what.. not exactly sure hoe the o2's even read which piticular bank is lean
Old Oct 2, 2006 | 10:15 AM
Zick's Avatar
I had a problem after putting in a new engine showing a lean code (maybe it was rich, can't remember exactly) but I fixed it by tuning the VE table.
Justin87gn
Sep 10, 2015 12:06 PM
custm2500
Sep 8, 2015 05:53 PM
bisqikss
Sep 8, 2015 03:35 AM
SWINGRRRR
Sep 3, 2015 07:49 PM
mr03silverado
Sep 2, 2015 11:43 PM
