quick question
hey i got the engine running good... turned out to be injectors so i put the 5.3 rail and injectors on till tomarow.... anyway so i was refilling my coolant and i looked down and the collector on the headers were glowing red.... not like cherry red but had a red tint to them.... now i havent ever really looked at them when the truck is hot but is this normal or not..... engine isnt over heating or anything just the headers are getting really hot....... now obviously i understand that the truck might be running a little lean with the 5.3 fule set up... so just give me a little input
Thanks
LES
Thanks
LES
Hot = Lean. The 5.3 injectors and the 6.0 injectors are the same. You've got a fuel problem somewhere. The tune won't make it "that" lean. Don't stand on it too hard until you figure out your problem. I'd check the fuel pressure.
i got the 6.0 tune in it now.... just desnt make any sence.... the 5.3 didnt run lean.....they were turning red after holding it at about 2500 rpm for 30 seconds
Did you get this str8 yet?
yeah..... not sure what the hell it was but it seemed to fix its self... ???? im still getting a false lean code from a leaky header... BTW codes read lean 1 and 2... now im only leaking on one side.... wouldnt it just show banks 1 , 3 , 5 , or 7 lean or what.. not exactly sure hoe the o2's even read which piticular bank is lean
SWINGRRRR
Sep 3, 2015 07:49 PM
mr03silverado
Sep 2, 2015 11:43 PM
