questions about Procharging my 5.3L?
Old Sep 1, 2003 | 06:23 PM
BlownChevy's Avatar
blownerator
25 Year Member
Default Re: questions about Procharging my 5.3L?
10 k with the radix, and 28 k with the side mount kit from magnacharger.
Old Sep 2, 2003 | 04:17 AM
Flyer's Avatar
$5K for the Radix, then another $2K when you 4L60E grenades in short order.
And another 400 in hardened parts at cost when that one grenades cause someone made it shift so hard it snapped the hardened input shaft in several pieces.
As long as you don't have a big truck, like Ext cab 4x4 or something .. you should be fine with a good shift kit and bigger servos.
By the time you get everything your gonna want/need with the ATI, you will have already spent around 4500-5000 on it. ATI kit is 3k, EDIT and ATAP, is about another k, injectors, another 500-700. I'm sure I'm leaving something out. Maybe Procharged LM7 will chime in .. I know he's beenthrough a lot.
EDIT:
Forgot to add .. the warranty on the RADIX is 3yrs/36,000 miles on the supercharger and componants itself. If installed by an ASE cert. mechanic, you can purchase the warranty through them to cover the engine and the drivetrain (tranny only) for 200 bucks which covers for 3 yrs/36,000 miles after a preliminary 1500 miles. They aren't as hard up about it as a dealership would be too. Which means you can do intakes, exhaust, headers, blah blha blah. You CAN'T change pulleys, or reprogram and still have your warranty, that's about all that will void your blower warranty.
I found out all the details before I did it, then I ended up installing it myself anyways. I wish I was ASE certified ...
Corvette454l88
Sep 1, 2016 01:24 AM
5.3lSilverado
25
Aug 29, 2016 12:48 AM
jrcabby
Aug 24, 2015 09:40 AM
USMCvet0311
Aug 1, 2015 07:45 AM
