Another intake part...
Old Aug 31, 2003 | 10:45 PM
Hit Man X's Avatar
Default Another intake part...
Well what do you guys think? If you look at the dyno on there the A/F is waaaaaaay off it seems to me on the first run. 13hp/23tq! Sounds a bit far fetched...
http://www.vararam.com/products03.html
Old Aug 31, 2003 | 10:58 PM
GREGGO's Avatar
Default Re: Another intake part...
I am under an obligation to test one for them in the very near future. Probably be a couple of weeks.
Old Aug 31, 2003 | 11:27 PM
Hit Man X's Avatar
Excellent, do keep us posted.
I was thinking about C5's again (I WILL have another) as they can go absurdly fast with just some bolt ons...and I stumbled upon the Vararam intake setup. Apparently they work great and so I went to their site and saw this truck piece.
Old Aug 31, 2003 | 11:44 PM
parish8's Avatar
single digit dreamer
that dyno is crap, on the first run it looks like it didn't go out of closed loop till the run was mostly over, either they didn't floor it at all or they floored it later than the 2nd dyno and there is a PE delay. either way they need a beter dyno test.
i dont doubt that it could help some bt if you goto look into the shanon or bower(i think) sites you can see where they do all that smoothing AND increase the actual inlet size. there is some kind of reduction right before the blade that that thing wont get rid of and now they actualy remove 1/2 or the shaft.
some unbiased dyno tests should be interesting, it would be nice to test one of the other popular ported TB's at the same time.
Old Aug 31, 2003 | 11:51 PM
Hit Man X's Avatar
Ah so I am not crazy, that dyno did look bad! But we shall see here in a few weeks.
Old Sep 1, 2003 | 12:22 AM
GREGGO's Avatar
The part does not decrease the inlet size. It tapers and stops before it gets to the blade. It basically looks like an ecentric reducer.
Old Sep 1, 2003 | 12:24 AM
XLR8NSS's Avatar
Adkoonerstrator
Greg - How did you get to test this thing out. It looks like they just molded a ported TB and made the part.
If it works as well as a ported/filled TB then it'll be worth the $49.
Old Sep 1, 2003 | 12:27 AM
XLR8NSS's Avatar
Adkoonerstrator
Hitman - I just noticed that A/F ratio on the dyno. That does look kinda fishy.
Old Sep 1, 2003 | 12:30 AM
parish8's Avatar
yes i realize that but there is a reduction in size in the stock TB that can be ported out, it is right before the blade. with that unit you are geting a smoother flow up to the smalest part of the stock TB but with the shanon unit you end up with a smooth and a larger bore and the cut shaft.
i cant wait to see the dyno numbers
Old Sep 1, 2003 | 10:25 AM
I have a Bauer ported throttlebody and the inside lip around the throttleplate is removed.The ported throttle makes a noticable difference in performance at the expense of throttle response.The loss in throttle response is noticable during cold engine operation.I attribute the loss in throttle response to the removal of the inner lip.It's possible that the insert could give most of the benefits of a ported throttle without the downside.
