Questions about heads????
Old Apr 28, 2004 | 10:16 AM
01Blackerado's Avatar
Question Questions about heads????
I'm going to get a turbo sooner or later but when i do i'm also gonna have the bottom end of the engine rebuilt, and i figured while the engine is apart i would go ahead and throw on some CNC port and polished heads too. Now the question is which head package i should go with. And the ones that I'm debating against are my stock heads (Ported and polished) or the LQ9 heads from the H.O. 6.0l(Ported and polished)????
Old Apr 28, 2004 | 11:14 AM
their is not a difference between the lq9 and the lq4. same heads. I would just stick witht he stock 5.3 and port and polsih them. their's something about the 5.3 going with bigger heads and the valves are to big. just have the 5.3 done(since you already have them it shold be cheaper and work great.
Old Apr 28, 2004 | 11:46 AM
BigTex's Avatar
Go with a cheap stage 1 ported LS1 head. It will lower you to just under 9:1 CR and you'll gain some flow. With a turbo, I doub't that you'll see tons more power going from stage 1 heads to a stage 2 head.
Old Apr 28, 2004 | 12:00 PM
is there a diff between LS1 heads and the LS6 heads???? And will they both fit the 5.3?? Thanx Tex your awesome dude!! Thank both of you guys actually both are great suggestions!!
Old Apr 28, 2004 | 12:40 PM
BigTex's Avatar
LS6 heads have a better port design and a smaller chamber size. But you'd benefit from the larger chamber of the LS1 head (if you go turbo or blower). A set of ported LS1 heads will outflow a set of stock LS6 heads. LS6 heads are expensive, LS1 heads are not. Just get 1999 or newer LS1 heads (centerbolt valve cover like the trucks).
Old Apr 28, 2004 | 01:02 PM
Sweet dude your a pimp thanx alot!!! Much appreciated
Old Apr 28, 2004 | 03:56 PM
Hey one more thing about that LS1 heads swap!! Will it lower or raise my CR???
Old Apr 28, 2004 | 03:57 PM
Nevermind im an idiot didnt read the second post. hehe
Old Apr 28, 2004 | 04:14 PM
what turbo are you going with.
Old Apr 29, 2004 | 08:44 AM
STS Turbo
5.3lSilverado
25
Aug 29, 2016 12:48 AM
USMCvet0311
Aug 1, 2015 07:45 AM
bbowerman
Jul 26, 2015 10:57 PM
sauldgold
Jul 23, 2015 02:15 PM
