Question on return,returnless fuel system
Old Aug 5, 2006 | 07:14 PM
Mangled03gmc's Avatar
Baltimore Whore
Originally Posted by DLH2006
Yep, You will need to get a new PCM because i am almost certian that the PCM off the 05 cannot be used on anything under 05. Sorry for not informing you of this on my last post.
So if I get a pre 05 6.0 computer it should work, the 05 comp I have now is poo...
Old Aug 5, 2006 | 09:16 PM
DrX's Avatar
DrX
You already have an 03 6.0 PCM. Same as the 4.8, 5.3. Either of your PCMs will work. They will just have to be tuned(programmed) for the 6.0.
Old Aug 6, 2006 | 01:57 AM
Baltimore Whore
Yes I have an 03 pcm but it is a 4.8 pcm. The only reason I got the pcm with the 6.0 is because I thought the timing and fuel tables might be different, with me putting this cam in that the 6.0 tune would be better suited for now untill I can get a tune done. So your saying that there isn't a difference between the 4.8 an 6.0 tune.. THanks JOHN
Old Aug 7, 2006 | 06:32 PM
DrX's Avatar
DrX
I meant that either PCM will work once tuned as long as the connectors are the same. Same PCM(hardware) for the 4.8, 5.3, 6.0, just different tunes(software). The PCM that came with the 6.0 will have the closest tune as is, other than your injector flow rate table(due to the returnless fuel system). Other tables will have to be changed though to get the most out of the cam.
USMCvet0311
Aug 1, 2015 07:45 AM
MS3Z
Jul 30, 2015 06:17 PM
GMCtrk
Jul 17, 2015 06:39 PM
4B11T
Jul 13, 2015 03:48 PM
