question about dakota digital fan controller.
here is a website with the instructions on how to hook it up
CLICK HERE
it looks pretty easy to hook up but i have a question..it says you have to hook up some wires to the fan relay, but i got flex-a-lite fans..my question is where is the relay for the fans...i guess they came in with a built in relay..how would i wire this up..help would be appreciated cause i want to get rid of my VSC....thanks
CLICK HERE
The flex a lite fan kit doesn't use a relay with the VSC- the controller is capable of providing the full current required by the fans. You will need to find a relay that is rated for the current draw of the fans you are using in order to use the Dakota controller. I bet a Bosch 40A relay would work just fine.
sorry i got some more questions..on the flex a lite fans it has 4 wires that connect to the fan motors...two on each...where would these go? on the relay cause i dont see a spot to put them on the device..and instead of tappin into the water sending unit i wander if i could use the temp sensor from the vsc? and connect it. sorry for all the questions ...its probaly wishful thinking that i'll get some answers cause im sure no one has one of these yet, but if some1 could help me out i'd appreciate it...thanks!
You can get automotive relays from crutchfield.com in the install section, summit, jegs, etc. One wire of each fan goes to ground, the other goes to power through a relay. The relay is what switches the fan on and off. There should also be circuit protection so a short doesn't burn your truck down.
