Project 6.0 has begun! ***Need Suggestions***
Old May 1, 2006 | 12:34 PM
  #41
Blaze5509's Avatar
Looks like your doing big things buddy!
good luck and hopefully I can learn a thing or three by following your thread.
Old May 1, 2006 | 12:41 PM
  #42
Colby 04's Avatar
TR224 and a Fuddle 3K should do it. Who is installing all of this stuff? Sounds like you are going to have a fun weekend:jester:
Thanks for the suggestion It looks like the TR 224 is a popular cam.
I'm installing everything....with the help of Beau....I think...
I won't have a problem doing the engine swap, that's fairly straight forward. I asked if Beau could help me with the cam swap since he's done a couple and I'd just like to have a little guidance on that part of it.
Old May 1, 2006 | 12:42 PM
  #43
Colby 04's Avatar
Originally Posted by dry_kill
How much did u end up paying for the engine? And where did u get it at colby?
$2077 shipped to my door, it was an ebay purchase from a company in Canada. The same company that sold "Thunder550" his 6.0
Old May 1, 2006 | 12:44 PM
  #44
Colby 04's Avatar
Now, keep this project over here on PT....I've got it on the down low over at FSC, I'd like to keep it that way
I hope you pick up some cam educations like I am. That's one aspect I'm a little uniformed about, but I'm getting there
Old May 1, 2006 | 12:46 PM
  #45
Colby 04's Avatar
Originally Posted by Z284thgen
SCR= static compression ration is what most people mention having this compresion ie 10.5:1 11.0:1 etc
DCR= dynamic compresion ratio this number is figured off cam timing and events and also plays a big factor in what fuel it runs on higher DCR= more octane needed to run good
hope i somewhat explained it to where you dont get all confused
good explanation.
The DCR, what good does knowing that spec do? What's the purpose of that calculation?
Old May 1, 2006 | 01:01 PM
  #46
FarmerBeau's Avatar
Sexy Party Mod
Worry not brother, It will be simple as pie. I just wish i could change my valvesprings on the engine stand. We'll get you all buttoned up with somethin fat and nasty.
Old May 1, 2006 | 01:06 PM
  #47
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Have fun dropping the motor in. Try not to crack the pump when getting the flexplate in the bellhousing. If gas wasnt so expensive I would drive down to Houston and lend an experienced engine swap hand but at 3 bucks a gallon
Old May 1, 2006 | 01:21 PM
  #48
Blaze5509's Avatar
Your secret is safe with me. I keep all the appearance and suspension related posts on FSC and sts.com and performance/engine/tranny related topics over here.
Old May 1, 2006 | 02:59 PM
  #49
Colby 04's Avatar
seems like I read a tip about jacking up the transmission in a way that allowed you more clearance for the flywheel...I'll be sure to reread those before I dive in on this though.
Old May 1, 2006 | 03:02 PM
  #50
1slow01Z71's Avatar
Yup put a jack under the front of the pan and jack it up as high as you can without crushing the pan the set the motor on down in there with the rear tilted down. You might want to buy a couple of big pry bars
