Project 6.0 has begun! ***Need Suggestions***
Old May 18, 2006 | 02:55 AM
  #71
thunder550's Avatar
High on diesel fumes
You should be fine doing it with the plug. I think you'll get most of the fluid that way.
Old May 22, 2006 | 07:21 PM
  #72
Colby 04's Avatar
Ordering the cam from Thunder Racing....
Should I get the gaskets from them? There is not any detail to what is included, it just says "cam gaskets". I've got a connection with GM for good pricing. Should I just pick up what I need from the dealer?
What will I need?
Thanks
Old May 22, 2006 | 07:37 PM
  #73
thunder550's Avatar
Timing chain cover gasket, water pump gasket, and valve cover gaskets are the ones that generally come with the cam swap kits. On my new motor I reused all of them, they are designed to be reusable, and I think you'd be ok with a low mileage engine.
The only gasket I replaced was the oil pan gasket when I changed the rod bolts, only did that cause it would be a bitch to replace after putting the engine in if it leaked. Didn't want to risk it.
Old May 22, 2006 | 10:19 PM
  #74
Colby 04's Avatar
I had heard they were reusable, but didn't know for sure. Since the cam swap isn't time sensitive, I'll just wait to see if I need them.
thanks for the reply
GMCtrk
18
Oct 6, 2015 03:48 PM
turbo6c3
Oct 5, 2015 06:11 PM
Cammed4ever
Sep 30, 2015 03:38 PM
xxloudogxx
Sep 28, 2015 12:30 PM
sTNT971
Sep 26, 2015 04:22 PM
