Project 6.0 has begun! ***Need Suggestions***
#42
TR224 and a Fuddle 3K should do it. Who is installing all of this stuff? Sounds like you are going to have a fun weekend:jester:
It looks like the TR 224 is a popular cam.I'm installing everything....with the help of Beau....I think...
I won't have a problem doing the engine swap, that's fairly straight forward. I asked if Beau could help me with the cam swap since he's done a couple and I'd just like to have a little guidance on that part of it.
#43
Originally Posted by dry_kill
How much did u end up paying for the engine? And where did u get it at colby?
#44
Originally Posted by Blaze5509
Looks like your doing big things buddy!
good luck and hopefully I can learn a thing or three by following your thread.
I hope you pick up some cam educations like I am. That's one aspect I'm a little uniformed about, but I'm getting there
#45
Originally Posted by Z284thgen
SCR= static compression ration is what most people mention having this compresion ie 10.5:1 11.0:1 etc
DCR= dynamic compresion ratio this number is figured off cam timing and events and also plays a big factor in what fuel it runs on higher DCR= more octane needed to run good
hope i somewhat explained it to where you dont get all confused
The DCR, what good does knowing that spec do? What's the purpose of that calculation?
#46
Originally Posted by Colby 04
Thanks for the suggestion
Worry not brother, It will be simple as pie. I just wish i could change my valvesprings on the engine stand.
We'll get you all buttoned up with somethin fat and nasty.
#47
Have fun dropping the motor in. Try not to crack the pump when getting the flexplate in the bellhousing. If gas wasnt so expensive I would drive down to Houston and lend an experienced engine swap hand but at 3 bucks a gallon
#49
#50
Yup put a jack under the front of the pan and jack it up as high as you can without crushing the pan the set the motor on down in there with the rear tilted down. You might want to buy a couple of big pry bars
