PROBLEM WITH K&N COLD AIR INTAKE -HELP
Old Jan 13, 2006 | 03:33 PM
shandy294's Avatar
If you get contact cleaner,make sure it doesn't have lubricant in it...just pure cleaner. That way you won't coat the MAF wires.
Old Mar 11, 2016 | 08:44 AM
25hdtankhauler's Avatar
Registered User
Your ecm isn't calibrating the extra air correctly. A tune wil resolve that issue. As for as KN quality .. I just installed a speed enginering CAI and they use the KN filter only. The kit was $72.00 shipped and a help of a lot better clamps and box.
Old Mar 11, 2016 | 08:51 AM
Registered User
Another option... Disconnect the MAF and run engine a few miles and check codes. The ECM will revert MAF readings and adjust fuel and timing with out it. Clear codes plug MAF in and see if it doesn't code again. Let me know....
Old Mar 11, 2016 | 10:07 AM
darsharley's Avatar
Registered User
who makes the CAI and were can I get it. also I will try disconnecting the MAF first, one's I get time to put the kit back on the truck.
Old Mar 12, 2016 | 05:39 PM
Registered User
Speed enginering ... Check them out on Internet ...
Old Mar 12, 2016 | 11:31 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Wow, A 10 year old thread bump...
Try starting a new thread on your issue that applies to the vehicle you're working on and give it more than 1 hour for someone to reply.
Corvette454l88
Sep 1, 2016 01:24 AM
shawn96gmc
May 17, 2016 04:15 PM
noproblems209
Aug 10, 2015 06:57 PM
Ketis
Jul 23, 2015 12:37 PM
Suburban2500
Jul 14, 2015 02:10 AM
