PRC duals mounting + install ?'s (valve springs + seats + seal)
Old May 23, 2008 | 09:29 AM
Tootall's Avatar
Default PRC duals mounting + install ?'s (valve springs + seats + seal)
does the seat go over the stock valve seal, or am I better off using the ones that come in the kit?
I'm getting at it now, so I haven't made the time to search around.
Old May 23, 2008 | 09:40 AM
ZZebes's Avatar
Seat Seal Spring Retainer Lock in that order
Old May 23, 2008 | 09:56 AM
Tootall's Avatar
so you're saying, skinny seal first, hammer down the black seat on top of that, then everything else?
Old May 23, 2008 | 10:02 AM
Moddoo's Avatar
You need to remove the stock seals and seats, then install all of the new parts.
Old May 23, 2008 | 10:05 AM
Tootall's Avatar
well I know that . . .
the new seal's OD is bigger than the ID on the seat for the new springs. I'm guessing I'll figure it it
Old May 23, 2008 | 10:20 AM
Moddoo's Avatar
LOL
I know you're no dummy, just trying to answer your question.
You asked about using the stock stuff.
It all has to come off.
I just want to make sure you don't do this
https://ls1tech.com/forums/showthrea...ighlight=seals
https://ls1tech.com/forums/showthread.php?t=916402
Old May 23, 2008 | 02:48 PM
CashDudeHomie's Avatar
I just read those 2 threads. Use everything in the kit. No stock stuff!!! I'm glad I didn't try to take any shortcuts when I did mine.
Old May 23, 2008 | 10:24 PM
Tootall's Avatar
LOL
oha no problem . .
I was just unsure of the order of the install.
Those threads are nuts! Great pics too. I've never seen a coil that binded that bad and took part of the head with it.
Old May 24, 2008 | 11:05 AM
gcsd3742's Avatar
Originally Posted by Tootall
oha no problem . .
Well good luck Too-TALL I'm counting on you to make it right....LOL Get me a video of the truck when your done....
Old May 24, 2008 | 11:21 AM
Tootall's Avatar
chopperloco
Jul 10, 2016 10:45 PM
bizle
Jul 22, 2015 07:31 PM
Offroadunleashed
Jul 20, 2015 02:25 PM
4B11T
Jul 13, 2015 03:48 PM
Mzay
Jul 6, 2015 11:05 PM
