317 heads
Old May 24, 2008 | 02:38 PM
Denali Dude's Avatar
Default 317 heads
Will the 317 heads raice the C.R on my 5.3 08 NNBS
and If they are milled will they rasie it?
Old May 24, 2008 | 02:54 PM
skeet's Avatar
if there milled, they will raise it!! but stock no i dont think they will
Old May 24, 2008 | 03:07 PM
Will I feel a Difference if I have a stock cam?
And is the texas speed cam 228R good for my truck witht the 317 heads and some 918springs and retainers.
Mods will be Cat back , S&b Intake , ASP pulley , And maybe i'll order pacesetters and try to do some mods on them to make them fit , And a Custom Tune ofcourse.
Old May 24, 2008 | 03:12 PM
LMSeven's Avatar
Your probably going to need to mill those heads so much to get any compression out of them you will run into shrouding issues.
If you don't mill them I'd imagine you'll loose a full point in compression at least.
Old May 24, 2008 | 07:22 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
no good for a 5.3....I dont think you could mill them enough to use on an NA setup.
Old May 25, 2008 | 12:07 AM
Richard@WCCH's Avatar
FormerVendor
I did a bit of research on this. I see that GM rates the factory compression ratio at 9.9:1 for '08 model. (See link) '08 factory Silverado engine specs
Your current heads have a 65cc chamber volume and the 317's have a 71cc chamber size. Putting this data into my compression calculator it appears that your new cr with the unmilled 317's will be 9.25:1. You would need to mill them .035" to get the chambers to the same cc your current heads are at. None of this is going to add performance because the ports on the 243 heads and the 317 heads are the same as cast. The only difference is with the combustion chamber sizes and shapes.
In short, stick with the heads that are currently on your engine. They have the best potential for making max power. Instead of replacing the heads look into an aftermarket cam and long tube headers.
Good luck,
Richard
Old May 25, 2008 | 12:11 AM
trever1t's Avatar
Good info Richard. I didn't know the '08's were alumium blocks too!
Old May 25, 2008 | 05:17 AM
I'm ordering the TSP 228R cam tommorrow with springs and other stuff Will I get power out of this cam or I move to something abit smaller?
Old May 25, 2008 | 12:31 PM
FormerVendor
You'll definitely need some stall in the converter with that cam.
Richard
greedygenius
Sep 3, 2015 06:51 AM
GrooveCityZ71
Aug 31, 2015 12:05 PM
Azim05
Aug 27, 2015 05:33 PM
darnie
Aug 10, 2015 10:25 AM
JordanH
Aug 8, 2015 07:59 PM
