possible 6.0 swap
Old Apr 3, 2009 | 10:50 AM
454navyss's Avatar
Default possible 6.0 swap
what all is involved in doing a 5.3 to 6.0 swap? a friend of mine has a complete 6.0 sitting in his shop that he said i can have for my truck. how do you tell a lq4 from an lq9? do i need to swap computers? what are some pros and cons from a daily driving standpoint? thanks
Old Apr 3, 2009 | 12:57 PM
00ChevyScott's Avatar
Wearin' da big hat
It wont fit, you should give it to me instead.
Old Apr 3, 2009 | 01:17 PM
jophuss36's Avatar
well it depends on what year it is, before 01 will not work and after 06 (in most cases will not work). With that said 03-06 being the best a lq9 will have 317 stamped on the head where as the lq4 will have a 2** stamped on the head. It's a fairly easy swap just use your accessories I would put a cam in while it's out, and stall if your going that route. The 6 liter gets about 1 mpg worse than the 5.3 but didn't use passing gear as much I'd say for a dd I like 6 liter better
Old Apr 3, 2009 | 04:23 PM
454navyss's Avatar
whats different about pre 2001 6.0s? he said he thinks it is a 2000 motor but isnt sure, he got it in a trade from a friend who got it from a friend who replaced it because it was "knocking" but ended up being a broken flywheel, not the motor
Old Apr 3, 2009 | 04:29 PM
454navyss's Avatar
BTW he has the wiring harness, computer, all sensors, accesories, etc
Old Apr 3, 2009 | 07:10 PM
jophuss36's Avatar
i believe that in the pre 01 6.0 there was something to do with the crank, and i was told wont fit with the 4l60e i could be wrong, ive never tried it but its what i was told a while back. kinda think of it there was actually just a post about that recently if you look threw a few of the treads on the board now
Old Apr 4, 2009 | 02:24 PM
agreif's Avatar
Pre 01 it'll still work, you'll just need to get a spacer. Not a biggie. Check my sig, swap is pretty straight forward.
Old Apr 4, 2009 | 02:26 PM
GMCtrk's Avatar
pre 01 will not hook up to a 4l60e period.
Just stick to the 2001 and up
Old Apr 4, 2009 | 02:31 PM
dlt76028's Avatar
not to mention pre 01 have iron heads
Old Apr 4, 2009 | 02:32 PM
dlt76028's Avatar
i dont know where you got this info but lq9 and lq4 have 317 heads.
