Popping noise on my exhaust??? 99-06 truck
Old Dec 17, 2019 | 10:10 PM
matslp488's Avatar
Default Popping noise on my exhaust??? 99-06 truck
Ok I’ve been chasing a popping/ clunking noise under my truck for about a month no with no luck... truck is a 05 silverado 6.0 fbos... the popping/ clunking noise seems to come right under my passenger side floor while idling and at lower speeds... I’ve already changed my torsion bar mount brackets and the noise is still there.... any suggestions??? Could it be my muffler???? Would that mean that it’s on its way out?? No codes thrown and the truck drives perfect...
Old Dec 18, 2019 | 06:25 AM
madmann26's Avatar
Cat material coming loose? I had that happen before it completely came loose and clogged up the exhaust.
Old Dec 18, 2019 | 07:25 AM
arthursc2's Avatar
Check for loose hangers, and for sanity's sake: check for popped off manifold bolts
Old Dec 18, 2019 | 09:35 AM
Alvin@PCMofNC's Avatar
Truck Sponsor
Is this factory exhaust or aftermarket?
Old Dec 18, 2019 | 10:19 AM
matslp488's Avatar
Thanks for the replies gents.... I will jack up the truck this weekend to check for any loose parts... the truck has long tubes, Y pipe and corsa muffler no cats...
Old Dec 18, 2019 | 11:08 AM
arthursc2's Avatar
Make sure nothing sagged enough to hit the cross members, or rub the body. Check the y pipe clamps too, and wiggle them when cold
Old Dec 18, 2019 | 03:25 PM
stroker87's Avatar
something rattling or something hitting?
while your under it just take a good look around and pound around the side of your fist see if you can get it to happen, had a similar thing going on with my sons truck it was the y pipe hitting the crossmember
Old Dec 18, 2019 | 05:42 PM
00pooterSS's Avatar
See if the piping is hitting anything. Worn motor mounts usually are the cause if it's all the sudden hitting.
Old Dec 21, 2019 | 08:55 AM
madmann26's Avatar
This also happened to me. My 3in ypipe was hitting the crossmember and had to be heated to massage it a little.
1SLOW4.3
Sep 6, 2016 07:13 AM
SlickSierra
14
Jun 10, 2012 03:02 PM
dropkick13
Feb 25, 2008 01:07 PM
RSTSilverado
May 8, 2005 08:19 PM
CashDudeHomie
Aug 13, 2002 12:22 AM
