This noise is driving me nuts
Old Jun 9, 2012 | 01:16 PM
SlickSierra's Avatar
Default This noise is driving me nuts
what do you think? seems to be on passenger side
MOV01458 - YouTube
Old Jun 9, 2012 | 01:31 PM
pasadenaman's Avatar
sounds like a lifter or a spark arching to something metel.
Old Jun 9, 2012 | 03:25 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Sounds like an exhaust leak on pass side.
Old Jun 9, 2012 | 04:45 PM
gnd111's Avatar
Does it get louder when you rev the engine?
Old Jun 9, 2012 | 04:49 PM
GMCtrk's Avatar
Seems like normal header type noise. Mine has always done the same thing.
Old Jun 9, 2012 | 06:42 PM
Cakes's Avatar
Sounds like a cracked header. This is not uncommon if the headers were only welded from the inside. In fact I just had to fix my Stainless Works headers for the same reason. I fixed them from the outside by welding around the primary onto the head flange.
Old Jun 9, 2012 | 06:55 PM
Does seem to get louder but hard to hear with exhaust and engine. i took off the fan and started it up and held a piece of tissue paper around both header flanges to see if it was leaking but there didnt appear to be any.
Old Jun 9, 2012 | 06:57 PM
always have a bunch of metal on the oil plug even at 8k miles on it
Old Jun 9, 2012 | 07:18 PM
GMCtrk's Avatar
can try spraying some soapy water. Bubbles = leak
Old Jun 9, 2012 | 08:06 PM
1FastBrick's Avatar
not if its leaking on the bottom side of the flange. There was another member chris that had this same issue. I had him pull the header on the Pass side and he found the crappy aftermarket gaskets actually deteriorated and were leaking mainly on the bottom side.
