place to purchase a Long block?
Old Nov 9, 2015 | 04:47 PM
  #21
YAMAHAGUY's Avatar
Originally Posted by George C....
You cant compare imports to these trucks
I asked age since you stated and only youngins mess with imports
Nothing complicated with these trucks
8mm
10mm
13mm
15mm
If you own these sizes you can basically do most work on them
It's not the physically removing and replacing I'm concerned about as I have the tools and knowledge to do so, it's the making sure I have everything on hand to make the truck run and drive properly once it's swapped. It's always the little things I might have missed with a wire, connector, correct tune, one gem came with a bolt hole and another didn't or want ever someone forgot to mention. I just find it really hard to believe that a 5.3 intake will fit on a 6.0, but if the only thing is different is the bore and stroke I guess y'all know better than I.
One thing nice about all those Hondas and Acuras the motors and trannys bolt right up with some wiring differences.
So far the only thing that isn't a direct fit is a 80E in the place of a 60E and there are some wiring mods.
Not just youngins mess with imports, there are plenty of old and young messing with some big imports like Supras or Lexus, Nissan, BMW, Audi.....lots of big power there.
Old Nov 9, 2015 | 04:49 PM
  #22
YAMAHAGUY's Avatar
Originally Posted by 86 IROC
As said before... if you use the same generation engine - EVERYTHING with swap over. Outward appearance between the 4.8/5.3/6.0 is exactly the same. I had a 2000 Silverado 5.3, I put a 2004 LQ4 in it. I reused my accessory drive, intake, exhaust manifolds, etc. This was my first time doing such a swap on this body style of truck. After the truck was totalled, I removed that engine. I now have a 2001 4.8 truck (251K miles and counting) and I guarantee that the same LQ4 will swap in without any issues.
Ok. I trust you guys since this seems to be the consistent answer. Now I just gotta get one :-).
Old Nov 9, 2015 | 04:51 PM
  #23
YAMAHAGUY's Avatar
So after all of you convincing me they swap then where is the best place to buy a factory GM spec 5.3 or a 6.0 long block?
Old Nov 9, 2015 | 04:58 PM
  #24
ezdaar's Avatar
whats budget and do you want go fast built into it from the start?
Old Nov 9, 2015 | 05:12 PM
  #25
YAMAHAGUY's Avatar
That's a good question. I do t have a budget in mind since I'd probably be buying everything as time goes. Truck $8k-$10k, motor/trans - $6000, rear end $1000, then what ever a future turbo kit might cost.
Old Nov 9, 2015 | 07:10 PM
  #26
madmann26's Avatar
Originally Posted by YAMAHAGUY
So you took all of your 5.3 accessories and intake, fuel rail, vaccum lines, coil packs, etc and put them on a .040 over 6.0? As far as tha actually bolting the motor in place of the 5.3 you shouldn't have had any issues and it's just like a more powerful 5.3 is sitting there. All wiring, ECU, throttle cable/DBW connection, etc was absolutely flawless????!!!!!!!!
Outside of retuning my VE table, yes.
It really IS this easy.
Old Nov 9, 2015 | 07:22 PM
  #27
Absolutely everything off of the 5.3 will bolt directly to a 6.0 harness PCM everything are exactly the same. Seeing as you are looking in the pre 07 then you need either a LQ4 or LQ9 6.0 Lq9 being preferable. Call scoggin dickey brand new ready to roll gm crate motor with a warranty. Drop it in take truck get it tuned by a custom tuner rock n roll. easy peasy
You can put in newer 6.0's and 6.2's and they are better performance wise but require more in getting intakes fuel systems and pcm's to cooperate.
Old Nov 9, 2015 | 07:31 PM
  #28
YAMAHAGUY's Avatar
What is the "VE table" ?
Old Nov 9, 2015 | 09:52 PM
  #29
TXsilverado's Avatar
Tuning jargon. whoever you choose as your tuner will take care of it.
Old Nov 16, 2015 | 11:21 AM
  #30
YAMAHAGUY's Avatar
So after believing everyone I decided to do another check and see what GM part #s cross reference and it all 4.8, 5.3, 6.0 part number are all the same. GM is awesome for that reason. I'm just so surprised to go from a 4.8 to a 6.0 in displacement they still use the same intake and TB.
