oil temp gauge
Old Nov 13, 2011 | 08:22 PM
hvactech08's Avatar
Default oil temp gauge
Where is the best place to install a oil temp gauge on a 6.0
I was thinking putting a tee on the oil on cooler line after it goes through it
Old Nov 13, 2011 | 08:33 PM
Atomic's Avatar
I have a gauge for that
I used one of these:
got it from ebay
Old Nov 13, 2011 | 08:51 PM
hvactech08's Avatar
What do ya call that exactly. And that would prob be the best way I think
Old Nov 13, 2011 | 09:16 PM
Atomic's Avatar
oil filter sandwhich plate, or something like that. They are all over ebay and are all the same pretty much. The adapter piece you need is 13/16-16
Old Nov 13, 2011 | 11:06 PM
ayousef's Avatar
which is gonna make me ask again, do our trucks have an oil cooler temp sensor somewhere? The ECU can read oil temp in Hptuners, but I read somewhere that reading is just a "guess" or something like that, can someone confirm this?
Old Nov 13, 2011 | 11:09 PM
Atomic's Avatar
99-07 definitely does NOT have an oil temp sensor. I dont know about 07+
Old Nov 14, 2011 | 07:18 AM
hvactech08's Avatar
On hptuners they take ambient temp and coolant temp to guess oil temp
Old Nov 14, 2011 | 06:03 PM
zeake's Avatar
I used a lingenfelter thingie.
I also added a huge oil cooler when I had the turbo. Now my oil never gets hot enough. about 140 degrees is it, Unless I really ride it hard for a little while.
Lingenfelter GM LS1, LS6 & LS2, LS3 Oil Cooler Adapter Kit - Lingenfelter Performance
Old Nov 14, 2011 | 07:40 PM
ayousef's Avatar
whats the point? this cannot by any chance have any accuracy at all, however its using more than just those parameters to calculate oil temp.
Id go WOT, the oil temp would rise quick, ill cruise for a while on the highway and it DOESNT drop, then when I stop for a while idling the temps would start dropping. not sure, but if thats the case then I definitely need an oil temp gauge, im ordering an expensive custom Ron Davis radiator with a built in oversized EOC and TOC + high-speed fans for this truck all based on the hptuners oil temp numbers.
Old Nov 15, 2011 | 09:11 AM
hvactech08's Avatar
That is what I was told so I don't know for a fact. But the only real way to know is a oil gauge...
Oobray
Jun 13, 2022 03:38 AM
600 horses
Sep 10, 2015 11:01 AM
the owl
Sep 4, 2015 04:09 PM
Matt C.
Aug 1, 2015 01:25 PM
dantheman1540
Jul 29, 2015 04:45 PM
