oil control issue
Old Jul 10, 2019 | 01:39 PM
  #21
arthursc2's Avatar
Valve guides don't usually go bad on these engines
quoting and bolding for all the ninnies who think they need to replace their guides to run a .600 lift cam
Old Jul 10, 2019 | 01:43 PM
  #22
1FastBrick's Avatar
Custm2500's Rude Friend
I wonder if someone made a mistake and installed a ring set upside down.
Old Jul 10, 2019 | 01:47 PM
  #23
firebladeJJ's Avatar
I'm thinking so, there had to be a mistake some where, but I'm still puzzled that if the ring packs were installed wrong on all or even one piston, I would thing it should have been smoking right off the bat. not a couple weeks later.
Old Jul 10, 2019 | 01:51 PM
  #24
1FastBrick's Avatar
It's true, I have seen engine's run low on oil, Not had the oil changed properly and look like tar inside, and well maintained engines.
Form 50K miles to 200K miles. None of them needed the guides replaced. These Powder Metal guides on the LS are pretty resilient.
Unless you bend a valve and crack a guide or something along those lines, I haven't seen one yet that needed even 1 guide replaced.
Old Jul 10, 2019 | 01:56 PM
  #25
1FastBrick's Avatar
Hard to say. Maybe you were just unlucky and all the rings lined up on a cylinder or 2 after they seated.
Unless you have an issue with 1 or both heads. I think with that much oil, it's going to be in the bottom end.
I am just as curious as to what the issue is.
Old Jul 10, 2019 | 02:01 PM
  #26
I think I'm gonna do a leakdown test and maybe pull the heads to see, but with this texas heat right now, its gonna be miserable, anyone wanna come over and help??? LOL!
I'll take a few pics during and maybe with the scope before I pull the heads.
Old Jul 10, 2019 | 02:22 PM
  #27
1FastBrick's Avatar
Sucks But might be a good start.
I would come over but im in CA.
Old Jul 10, 2019 | 02:37 PM
  #28
it might be worth burning the oil to drive there. probably not 108 heat index right now in cali.
Old Jul 10, 2019 | 02:52 PM
  #29
1FastBrick's Avatar
Only about 88 where I am right now...
Old Jul 10, 2019 | 05:24 PM
  #30
arthursc2's Avatar
Im not arguing that at all! Its just that I tried to sell my WCCH heads and some ninny thought it was fair to lowball me on the grounds that "he would just feel better replacing the guides for his .600 lift cam"
Yeah, no. Only LS7s have had issues that I have ever read
