oil control issue
#23
I'm thinking so, there had to be a mistake some where, but I'm still puzzled that if the ring packs were installed wrong on all or even one piston, I would thing it should have been smoking right off the bat. not a couple weeks later.
#24
Form 50K miles to 200K miles. None of them needed the guides replaced. These Powder Metal guides on the LS are pretty resilient.
Unless you bend a valve and crack a guide or something along those lines, I haven't seen one yet that needed even 1 guide replaced.
#25
Unless you have an issue with 1 or both heads. I think with that much oil, it's going to be in the bottom end.
I am just as curious as to what the issue is.
#26
I think I'm gonna do a leakdown test and maybe pull the heads to see, but with this texas heat right now, its gonna be miserable, anyone wanna come over and help??? LOL!
I'll take a few pics during and maybe with the scope before I pull the heads.
#27
I would come over but im in CA.
#30
It's true, I have seen engine's run low on oil, Not had the oil changed properly and look like tar inside, and well maintained engines.
Yeah, no. Only LS7s have had issues that I have ever read
