Official NBS V6 to GENIII V8 swap Guide
Old Aug 21, 2017 | 11:28 PM
  #191
FFDP's Avatar
Originally Posted by steve5.3
read through the whole forum im am performing this swap right now and ran into an issue i have a 2003 silverado extra cab short bed and i am outting in a 5.3 from a 2005 silverado.. i am trying to make it drive by cable like my v6 was so i purchased a harness from a 2000 cable driven silverado. one of the connectors under the fuse box does not match, it could connect if the key ways were cut off but i dont know if it would still work. so should i cut off the keyways or go through the hassle of switching the entire harness to dbw
any help would be greatly appreciated thanks
steve
You should have got a harness to match the motor and then found a P59 computer with IAC drivers in it to then make that P59 DBW computer into a cable computer. There is a small write up on here for what wires need to added for the cable swap.
I wouldn't cut the connector to make it fit, more than likely the wiring from 2003 is not the same for 2000 which your harness is from. The wires in your harness may not control the same things on each pin as the 2003 fuse block.
Old Aug 22, 2017 | 07:58 AM
  #192
tpartsman's Avatar
Default steveo if you read the entire post you would know this.
steve
Besides for cruise control working, it is much easier to change the pedal and tac module. I still have not even looked at the cruise control wiring. I too wanted cable but ended up dbw.
Old Aug 23, 2017 | 01:48 AM
  #193
Harleyjim83's Avatar
What about neutral safety switch on harness with if you have nv3500
Old Aug 30, 2017 | 10:35 PM
  #194
steve5.3's Avatar
Registered User
what is van os?? thankyou
Old Aug 30, 2017 | 10:40 PM
  #195
FFDP's Avatar
Well van likely means a chevy or gmc van and OS means operating system.
You didn't quote where you found this so this is my best guess.
Old Aug 31, 2017 | 07:55 PM
  #196
steve5.3's Avatar
Registered User
i take there is a procedure to getting the formorly cable driven truck to have cruise control with the new dbw system?
Old Sep 4, 2017 | 07:28 PM
  #197
steve5.3's Avatar
Registered User
Finished the swap on my 2003 ECSB installed the dbw tac and pedal it starts and runs but i have no guages and the pedal does move the throttle body. when i turn the key to just fuel pump everything turns on in the instrument panel but as soon as i crank it all guages shut off.any idea what this could be i have not performed the passkey re learn or crankshaft re learn.
Old Sep 4, 2017 | 08:11 PM
  #198
steve5.3's Avatar
Registered User
Update fixed the guage issue still no pedal action from it at all..
Old Sep 10, 2017 | 10:30 AM
  #199
jay adams's Avatar
Registered User
Default 99chevy standard cab silverado 4.3 to 5.3 L33 swap with 4l60e tranny
can any one give me any tips other the go carb. how everything should work . can I use the tranny that came stock with my 99?
how much engine harness do I need? can i use my harness and computer? do i need to change my motor mounts.
Old Sep 11, 2017 | 12:51 PM
  #200
kush killer's Avatar
Any info on putting a 99-02 engine&ecu into a 03-06 truck?
