Official NBS V6 to GENIII V8 swap Guide
Old Mar 6, 2017 | 09:28 PM
  #171
spaccord's Avatar
Default Gas pedal install
On my 2004 v6 the gas pedal I mount to a metal bracket that seems to go around steering column and all im lost how to install the dbw gas pedal
Old Mar 7, 2017 | 08:39 AM
  #172
tpartsman's Avatar
Default Grinder self tap sheet metal screws
I ran in to the same problem. I cut my gas pedal off and used two self tapping sheet metal screws to mount the new dbw pedal and two tack welds just to be safe. I have not had any problems in 15 months and drive it every day. The only other option pull the column and that big metal bracket. I was not willing to do that especially the truck was sitting there at idle. I was ready to test drive it.
Old Mar 7, 2017 | 08:45 AM
  #173
tpartsman's Avatar
Default pretty much
thanks man probably will be going dbw and getting a 2004 5.3 harness, gas pedal and throtle body. just hope all the connectors on my 2001 5.3l are the same
As far as I can think of everything should be the same alternator maybe different but, crank,cam,map,maf, will be the same. 02 sensors maybe different plug as well as injectors if it was flex fuel.
Old Mar 7, 2017 | 09:45 AM
  #174
spaccord's Avatar
that will work for me thanks for the advice.
Old Mar 7, 2017 | 09:46 AM
  #175
spaccord's Avatar
not flex fuel so i think ill be good
Old Mar 11, 2017 | 09:54 PM
  #176
5.3Caprice's Avatar
Driver side motor mount identification (1500 models only).
Top mount is coil spring V6, middle is coil spring V8, bottom is torsion bar V8.
Old Apr 19, 2017 | 03:01 PM
  #177
Hotzejoey's Avatar
Registered User
Unhappy dying on me
Okay so i have 2005 Silverado 4.3 5 spd and did the 5.3 4l60 swap. Got a complete swap from a 2002 Silverado. so my problem now is it will run and drive but if you give it to much gas it dies. so at this moment i am unsure if the problem lies in the connector going into the fuse box being pinned differently considering the fuse boxes are different from a 2002 and 2006. i already did a bunch of repining to get it to turn key and fire off but now i am here. so has anyone had this problem? if so i need to get a wiring harness out of an 04-06? could it be a tune issue? any help would be greatly appreciated thank you all!!!!
Old May 7, 2017 | 02:58 PM
  #178
II Fast's Avatar
Just the info I was looking for, Thank you for taking to time to post this!
Old May 29, 2017 | 01:05 PM
  #179
the33z33's Avatar
I have an 07 classic that I'm putting in a 5.3 from an 05 suburban. I grabbed the trans with it for simplicity of the swap. Both are return less fuel so that makes that simple. Both already came set up to run e-fans so that helps too. My questions are, will the frame mounts for the suburban work for the silverado or must they be silverado mounts?
also... where does this connect? I don't think I see one on my v6... though I haven't pulled it yet to be sure.
and what the hell is this even?
Comes from the trans.
Old May 29, 2017 | 03:39 PM
  #180
FFDP's Avatar
1. Is the EVAP hose that leads back to the tank. On the V8's the 3/8th feed line and the EVAP line come up together on the rear of the motor.
2. That is just the breather for the transmission, they place it there so it's far above the fluid level to vent it and to not get crap around it and plug it up.
