No oil pressure
Old Apr 15, 2007 | 09:13 PM
Did yall have 0 psi oil pressure with the faulty or stock o-ring?
Old Apr 15, 2007 | 09:32 PM
RandomHero's Avatar
Well I don't know because I replaced the oil pump and o-ring. We took the oil pump apart just for ***** and giggles and everything looked damn near brand new. It's basically only like 4 parts the housing, spring, screw and valve
Old Apr 15, 2007 | 10:21 PM
Quik's Avatar
5 year bitches!
liek stated i had psi for about 60 seconds and the truck shut off. the low psi light flashed. i started it again. none. killed the truck. and then the next day tore it down to find
Old Apr 16, 2007 | 11:06 AM
Tootall's Avatar
use the red one, it's over sized and fits great
Old Apr 16, 2007 | 12:21 PM
FarmerBeau's Avatar
Sexy Party Mod
I installed the oil pump and the o ring. We didnt have a new oring on hand so we used the stocker. When i did my tchain swap, i totally shredded the o ring and still had 20lbs at idle. I have never heard of zero oil pressure. I would lean towards the pump being defective or something stoping that little piston (Cody brought this point up) within the pump itself. I heard something about there being two different sized o rings. The pump he is using is a ported ls6 oil pump and i dont know whether it uses a different o ring or not. Ummmmmmmmmmm Im lost!
Old Apr 19, 2007 | 09:45 AM
Changed the pump and the 0-ring. Don't know which was bad. I know the o-ring was at least part of the problem, but I was tired of tearing this thing apart. I am happy now, Thanks for the replies.
Texas5.3_1251
Mar 5, 2016 08:10 PM
69z-28
Sep 21, 2015 07:31 AM
Go5.3tt06
Sep 14, 2015 02:11 PM
Brandonlflr12
Sep 8, 2015 09:01 PM
Boyes50
Sep 8, 2015 12:06 PM
