No oil pressure
Old Apr 15, 2007 | 12:39 PM
Default No oil pressure
I did heads/cam swap with LS6 oil pump. I have nothing. I let it run for a few seconds. Going to pull the valve covers to see if oil is getting up there. If not then we will check the O-ring. I used the original 5.3 o-ring. Is there a difference between it and the LS6 o-ring? Anyone have any other ideas?
Maybe oil pressure sending unit?
Old Apr 15, 2007 | 12:55 PM
Unless you dropped or banged the sending unit it should be bad. Deffinatly check take the valve cover off and check. Usually if the o-ring is tore or something it will have oil pressure but will be very low.
Old Apr 15, 2007 | 03:34 PM
Pulled the valve cover, turned it over and got nothing.
Old Apr 15, 2007 | 03:49 PM
It is possible to get a bad oil pump. I think it was randomhero on here that had simular issues with his cam swap. Maybe PM him or he will chime in with some insight.
Old Apr 15, 2007 | 07:12 PM
Quik's Avatar
5 year bitches!
its your O ring. just replace it and youll be fine. my 408 lost all psi after 60 seconds of run time. put new Red O ring in place and it was beautiful PSI
Old Apr 15, 2007 | 07:33 PM
RandomHero's Avatar
Yup I did have a problem with the oil pump failing.
Make sure your o-ring is installed correctly!!! I didn't touch the oil pump when I did my cam install, but it failed when we put everything back together. When we took the oil pump and oring off the oring was sqare and about half the size(thickness) of the new oring.
Old Apr 15, 2007 | 07:48 PM
I pulled the cover off the oil pump, the o-ring looked good, but I will replace it. It's only a dollar. I am going to check and see if the pick-up tube is on the bottom of the pan.
Old Apr 15, 2007 | 09:04 PM
Quik's Avatar
5 year bitches!
the first O ring i used was too loose. the new one was nice and tight along with being fat
Old Apr 15, 2007 | 09:10 PM
RandomHero's Avatar
yup the one I went and got had cheap red paint on top of it. Once you get the red paint off of it the oring is a dark orange.
I haven't had a problem since(knocks wood).
Old Apr 15, 2007 | 09:12 PM
part #? Is there anything else that could be wrong besides what thas been discussed? Pump has remained dry thorugh out all the things I have done. I even primed the pump by soaking the gears(? what ever they are called) in oil. Thanks a lot for all the help!!!!
