No oil pressure
Originally Posted by sleek silverado
Did yall have 0 psi oil pressure with the faulty or stock o-ring?
liek stated i had psi for about 60 seconds and the truck shut off. the low psi light flashed. i started it again. none. killed the truck. and then the next day tore it down to find
I installed the oil pump and the o ring. We didnt have a new oring on hand so we used the stocker. When i did my tchain swap, i totally shredded the o ring and still had 20lbs at idle. I have never heard of zero oil pressure. I would lean towards the pump being defective or something stoping that little piston (Cody brought this point up) within the pump itself. I heard something about there being two different sized o rings. The pump he is using is a ported ls6 oil pump and i dont know whether it uses a different o ring or not. Ummmmmmmmmmm Im lost!
Changed the pump and the 0-ring. Don't know which was bad. I know the o-ring was at least part of the problem, but I was tired of tearing this thing apart. I am happy now, Thanks for the replies.
69z-28
Sep 21, 2015 07:31 AM
