need some help tuning cam
Old Jun 2, 2004 | 09:25 PM
mwalls54's Avatar
Need More N2O Mod
Default need some help tuning cam
ok i am in the process of installing a custom grind comp cam
214-220 559-564 116
any one give me any ideas what i need to change in my tune using edit.
i have my shift points up with my rev limiter up to about 6300
Old Jun 2, 2004 | 10:41 PM
BigTex's Avatar
That cam looks familiar. I bet it will run very good on the juice. It won't need very much tuning to run well.
Set your idle rpms at 700. In the lower temp range, the value will be higher, so leave them, just change them when they drop below.
You may want to start with shifts in the 6200 range. Move your rev limiter over to 6500. That way if the trans gets sloppy on the spray, you won't hit the limiter. I've had my trans slip several hundred rpms while spraying.
Old Jun 2, 2004 | 10:57 PM
Mr. Sandog's Avatar
Just curious mwalls - you replacing the retainers and pushrods, or just the springs?
Old Jun 2, 2004 | 11:09 PM
mwalls54's Avatar
Need More N2O Mod
just springs this time, and replacing the retainers that the suspension eats when i drop them.
Old Jun 2, 2004 | 11:43 PM
FarmTruc's Avatar
Performance Trucks Sponsor
Hey walls, if I remember correctly, didn't you have a soldering iron at the track meet?
I know this sounds like it has nothing to do with tuning, lol. Just wondering.
thanks,
allen
Old Jun 3, 2004 | 12:21 AM
Flyer's Avatar
soldering iron??
There was an article I remember parish posting about on another board that had some good info on it. Basically they raised the idle air tables some, raised the idle, and adjusted the VE in the lower rpm's. THey also adjusted timing at low rpm's too.
Old Jun 3, 2004 | 05:30 AM
mwalls54's Avatar
Need More N2O Mod
thanks,
allen
yep that was me
Old Jun 3, 2004 | 11:37 PM
Glad you started. Let us know how it runs.
ARC
57
Feb 21, 2022 10:54 AM
Matt331
Jul 26, 2015 09:40 PM
ssierra08
Jul 15, 2015 06:40 AM
4B11T
Jul 13, 2015 03:48 PM
all_individual
Jul 13, 2015 11:01 AM
