need some help tuning cam
Need More N2O Mod
ok i am in the process of installing a custom grind comp cam
214-220 559-564 116
any one give me any ideas what i need to change in my tune using edit.
i have my shift points up with my rev limiter up to about 6300
214-220 559-564 116
That cam looks familiar.
I bet it will run very good on the juice. It won't need very much tuning to run well.
Set your idle rpms at 700. In the lower temp range, the value will be higher, so leave them, just change them when they drop below.
You may want to start with shifts in the 6200 range. Move your rev limiter over to 6500. That way if the trans gets sloppy on the spray, you won't hit the limiter. I've had my trans slip several hundred rpms while spraying.
I bet it will run very good on the juice. It won't need very much tuning to run well.Set your idle rpms at 700. In the lower temp range, the value will be higher, so leave them, just change them when they drop below.
There was an article I remember parish posting about on another board that had some good info on it. Basically they raised the idle air tables some, raised the idle, and adjusted the VE in the lower rpm's. THey also adjusted timing at low rpm's too.
Need More N2O Mod
Originally Posted by FarmTruc
Hey walls, if I remember correctly, didn't you have a soldering iron at the track meet?
I know this sounds like it has nothing to do with tuning, lol. Just wondering.
thanks,
allen
thanks,
allen
yep that was me
ARC
57
Feb 21, 2022 10:54 AM
all_individual
Jul 13, 2015 11:01 AM
