Need some HELP!!
Old Aug 25, 2017 | 11:35 AM
  #31
truefire04's Avatar
The issue still remains, what are the maf sensor readings supposed to be, I'll check that out tomorrow.
Old Aug 25, 2017 | 04:55 PM
  #32
RPMSpeed Tech's Avatar
Truck Sponsor
Are you reading g/s or hertz (hz) or lb/min?
Old Aug 25, 2017 | 07:04 PM
  #33
truefire04's Avatar
I haven't done it yet, I'llrecord it and post it up here, not sure what it will be tho.
Old Aug 26, 2017 | 02:19 PM
  #34
truefire04's Avatar
ok here is the video of the maf sensor, not sure what all you needed but i addded a few others to it.
  #35
truefire04's Avatar
sorry for the blower in the back ground
Old Sep 2, 2017 | 05:45 AM
  #36
truefire04's Avatar
i gues this thread died... but i still need help!!!!
Old Sep 2, 2017 | 12:21 PM
  #37
Truck Sponsor
Your fuel trims are fine. the one side is switching back and forth but always negative and pass side is -3.4 which is ok also.
What is the issue still?
Old Sep 2, 2017 | 01:32 PM
  #38
truefire04's Avatar
still having the same issue, with it missing, or stumbling, i changed out the fuel pressure regulator and pcv valve with no change. is there a way to text the pcm to see if its bad, or is that something i will have to take to dealer to test?
Old Sep 2, 2017 | 01:35 PM
  #39
Truck Sponsor
Unplug the maf and drive it. See what happens.
Old Sep 2, 2017 | 01:44 PM
  #40
truefire04's Avatar
did the maf look bad? that was a 2 min video, i checked it while driving around 80mph, and the lowest it got was i think 20. something and the highest was i want to say 45. something, on the gr/se.
